Rapids hob ID (1 Viewer)
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
We have a small problem with the hob in our van it needs a new thermo coupler I can not I'd the model and am fed up waiting for Dometic to get back to me.
The model number says EK2000 but that is only a 2 burner ours is a 3 burner.
Steve and Denise
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
Yes I did try that but still no corosponding number I will ask dometic at the show this weekend.
It is most likely to use popular to most jobs type coupler I am just a bit peeved Dometic have not got back to me.
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
We've got a similar Cramer Dometic hob.
Can I ask why you think you need to replace the thermocouple?
The reason I ask is because we had a problem with one gas ring which wouldn't stay alight. I fiddled with the spade connector underneath the unit and bingo it worked again.
Steve and Denise
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
All three light but if you tap on or near the hob one of the flames goes out so I assume it will be a coupler I had a little wag of the wires but no joy.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Try checking that the thermocouple connection nut on the control for the relevant burner is tight. A thermocouple will not fail in such a way that a tap will bring on a fault. Flame failure thermocouples are pretty standard across all gas appliances fitted with them. If you ask a plumber's merchant for a 'universal' one it will fit.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
It could be corrosion, caused by water dripping thro the tap.
Also there should be a little metallic sticker somewhere underneath that has a number on it, you can use this to ID the hob
Steve and Denise
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
Ok just had a mess about ie cleaned the hot end so to say had a tap around the valve block and now can not get it to go out strange! but true:)
