rapido toilet door lock (1 Viewer)
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
Hi funsters, Having trouble with toilet door lock, handle drops and wont keep door closed result is door swings open when traveling, any rapido owners had this problem ? :Sad:
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
I have no problem keeping mine up........:RollEyes::RollEyes:
Travelling or stopped........:thumb:
EthnGeoff
263
236
County Durham
Low Profile
April 2009
It's a domestic type handle on the Rapido, I would suggest taking it apart and making sure everything moves freely.
Geoff.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
Sounds to me like return spring inside handle has broken.
remove handle and check,return springs are pretty standard
you should be able to source one from any old household door
handle. there is normally a spring on each handle ie. inner and outer.
looks like both could have broken.heres a link so you can see what your looking
for
Broken Link Removed
hope this helps regards
Steve
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Funny thing, mine does the same, however if you put the handle up by hand it stays there so probably only one spring broken on mine. Let us know how you get on fixing yours and I may get round to fixing mine before the other spring goes.:thumb:
JohnM
JohnM
650
179
Central Scotland
CClass
I have looked in to this online it would appear that the door lock is a weak point on rapido. There is a thread on the dark side regarding this problem cost of replacement £200.:Angry:
makems
3,439
27,697
Ingleby Barwick,,Teesside
Sadly had to give up
I had a similar proble this summer.
I took apart the handle and found the spring had slipped out of position but it wasn't broken.
Be careful as you take the assembly apart - it took me ages to find the spring after it pinged out (bugger).
It also took a couple of minutes to work out how to put it back but since then it has worked perfectly.
You'll need a small Allen key to get the handle off.
Hope that helps
Mike
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
you could always stick a bungee cord on the handle and over the top of the door as a temporary measure :thumb:
