Rapido Headlights
Discussion in 'Rapido' started by laird of Dunstan, Mar 11, 2016.
  1. laird of Dunstan
    laird of Dunstan Funster Life Member
    Feb 15, 2015
    1,397
    3,774
    lincolnshire
    Hi Guys
    does anyone know if a rapidos headlights can be adjusted so that the beam can be moved to the left? im picking up a rapido LHD and i need the headlights to adjust to the left
  2. Mr B
    Mr B Funster
    Feb 1, 2015
    400
    987
    yorkshire
    image.jpeg Here you go
    Jack front end up, remove wheels and there is an access cover, remove it and you can get to the little blighters. Or ask the dealer to do it :)
    • Like it Like it x 2
    • Informative Informative x 1
  3. laird of Dunstan
    Feb 15, 2015
    1,397
    3,774
    lincolnshire
    you are a diamond mr B, my stress level has gone down , the belgian dealer was not sure if it could be done ,i had a nightmare senario in my head of having to wait 8 months for replace ment lights
  4. Mr B
    Mr B Funster
    Feb 1, 2015
    400
    987
    yorkshire
    Don't get stressed, it happens when it happens. Just enjoy your van when the VCA has done with you. Use this forum to get your wording right when you send off your forms :)
  5. makems
    makems Funster Life Member
    Sep 23, 2011
    2,718
    11,051
    Ingleby Barwick,,Teesside
    I used to be able to do it through the open bonnet. Admittedly it wasn't easy as you couldn't see the screws and neede the use of a mirror and a torch. Eventually I could do it in less than ten minutes.
    • Like it Like it x 1
  6. makems
    Sep 23, 2011
    2,718
    11,051
  7. Sheddy
    Sheddy Funster
    Oct 20, 2010
    951
    4,769
    Burry Port South Wales / Benidorm
    I also did ours through the wheel arch covers, just make sure the 2 screws you loosen allow the body of the light to be pulled back about 3mm, then it can be rotated easily. Be careful not to use excessive force because the brackets fixing the whole light assembly to the vehicle body are not that strong and can be easily bent. The plastic retaining fixings for the wheel arch covers are extremely difficult to refit, I eventually used large cable ties with a small hole drilled adjacent to each fixing hole.
    So if you can manage to get to them from the bonnet it would save the hassle of the plastic fixings, also if you need to adjust the beams I think you will need a 7mm socket for the adjuster screws. My local friendly Mot garage allowed me to do mine on the ramp.
    Good luck
    Ed
    • Informative Informative x 2
    • Useful Useful x 1
  8. laird of Dunstan
    Feb 15, 2015
    1,397
    3,774
    lincolnshire
    once again the forum joining fee looks like a bargain(y) ,thank you for the input , i have a tool for the wheel arch fixings so that route looks a possible ,ill take a look through the bonnet and weigh up which way i think will be easiest:D
  9. Mr B
    Mr B Funster
    Feb 1, 2015
    400
    987
    yorkshire
    Unless you've got hands and arms like posh spice, you'll be under the wheel arch like us normal umans;)
  10. laird of Dunstan
    Feb 15, 2015
    1,397
    3,774
    lincolnshire
    its looking like its coming together:D
  11. vicwo
    vicwo Read Only Funster
    Mar 18, 2016
    57
    38
    South Yorkshire
    I'm picking up a new A class in June. Never gave a thought to headlights. We go to France quite a lot. I normally use stickers on my present low profile. Hmmm thinking time Vicwo
  12. hilldweller
    Dec 5, 2008
    27,751
    26,838
    Macclesfield
    Just to clarify, for your doubters, that was one post for the LHS and another for the RHS.
    • Funny Funny x 1
  13. laird of Dunstan
    Feb 15, 2015
    1,397
    3,774
    lincolnshire
    if your going to register it in the UK,you will need a speedo insert from Lockwoods ,change the lights to beam to the left , the fog light needs to be on the right hand side at the rear
    • Useful Useful x 1
Similar Threads
  1. Titley
    13
    440
  2. Greenway
    5
    310
  3. Bobby22
    25
    1,114
  4. Weebmitch
    4
    517
  5. Techno
    14
    1,539
