- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
It's always bugged me that the tap is illogical in that this is the closed and travelling postion
I know others have felt the same and altered theirs, today was my turn.
You need to drill out the two rivets as pictured above and then the whole assembly will pull out and away from the tank.
When removed this screw & nut needs removing
Then with the screw removed it requires a decent pair of pipe grips on the plastic interface whilst turning the tap at the other end through approx 90 degrees.
Then re drill the hole for the screw and nut.
When replaced it looks like this
And now
OPEN
CLOSED
Broken Link Removed
And now
OPEN
CLOSED
Broken Link Removed
