Rapido and FIAMMA 77 bike lift (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Template for top fixing points knocked up from aluminium angle
Marked a pencil line across from side to side in line with the bottom of the curved panel.
Measured the centre and used the template to mark the holes for drilling.
Hung the rack on the top hangers and then centred the bottom brackets to mark for drilling.
Top tip!
To make sure the drilled holes are at 90 degrees to the wall use a block of wood with a 6mm hole made using a pillar drill.
Once you've drilled into the skin of the van STOP and put your drill bit through the wood into the hole and hold the wood tight to the van then proceed to drill right through.
All 8 of my fixings aligned perfectly with the internal plates.
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Nice job.
Just got to find the balls to drill my Rapido.
Did you put any spacers in the bodywork to stop it crushing.?
Great photos
Mel
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
No it won't crush, you can feel when it is tight enough.
You could always use the rapido drill and tap fixing points but the consequence is that the rack will be 300mm off centre
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
I think yours looks beter in the centre.
I was looking at the Thule Omni-Bike Lift.
But the Fiamma one looks ok .
Like I say just got to dare drill it .
What toilet do you have in your Rapido?
We have the dommetic CT3000 and the flush has very little power.
Just had a call from the dealer if we need more power we have to fit a beter pump.
And its not warranty.
I will be ringing Rapido in the morning.
Mel
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Bog with a sog is a Thetford C200
Omnistor bike rack has a lower payload.
I think Omnistor make better awnings but the Fiamma is a clear winner on bike lifts
Drilling is EASY, getting the holes in the right place is the hard bit
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Omnistor do an electrically powered option but I'm going to make an attachment for my Makita 18volt battery drill :thumb:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Making a template for the upper fixings is the key to making it easy as the width is critical. Once the rack is hung on those it is relatively easy to mark the bottom ones through the brackets once centered.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry but you're wrong Peter.
I've watched this for over 6 months now and they don't have them in stock (available) is what they quote. Delivery takes 10 days from placing order. They just don't make as much profit.
It's not a sale price either it's a "our price"
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Your right :Doh: I saw the red sale link!
We can do them at that price but in our experience this rack causes a lot of problems with buyers unless they are well clued up like you, had a Sundance (used) go out yesterday with one already fitted and the buyer was not happy with it but that is what it came with.
Peter
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I badly sprained my wrist loading and unloading bikes on the last van through overstretching even stood on a stool :cry: (short arse) Having it at knee height is teriffic especially now I've electrificated it :roflmto:
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
This is an excellent install and exactly what I've been looking for. My van has a rear toilet so the existing Omni rack is mounted very high and me being short = steps, over reaching and huffing n puffing, honestly it's the most stressful part of the whole vacation prep. Last Thursday was the last straw and I simply ditched the bikes and put the scooters in the garage as it was easier. Getting the cover on at that height is nearly impossible....
Going to read through this thread again and check the pics as I need to get a good understanding about the fixings and need to know if I can use the existing drill holes that are already there. The height is fine as my Omni is 100cm and the Fiamma lift covers 68 - 106cm from memory, need to check the width and then the hole centers on the plates.
Looked today at Omni fixings but there is nothing on the inside of the van, it looks like they are drilled into the top rail where I assume it has a fixing batten behind it (need to check with manufacturer) and the bottom looks like it is purely Sika fix.......
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thule / omni
also do a bike lift but it has a max payload of 50kg and probably more expensive.
Good luck with it and please update us
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
Thule / omni
And has a 3 bike limit. That's why I'll go for the Fiamma if I can find a solution for the fixings.
Would there be any chance that you could measure the holes centres on the upper and lower brackets ?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm in Sorrento just now for a wedding so no :roflmto: but centre to centre of brackets is 600mm you can probably get the fiamma instructions off Peter's website Johnscross.
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
Yep got the instructions on line but they don't give the bracket info I need, may just go ahead and order from the site you posted, excellent price:whatthe: and find a solution some how....
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I can't imagine there being a significant difference :thumb:
Btw my rack is set at 107cm to give you an idea of scale
I'm back home Friday night
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
50mm :thumb:
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
50mm :thumb:
That's great, the brackets on the existing Thule is also 50mm.
Had a good look at it today and it seems pretty OK to swap the rack out for the Lift 77. Some adaptation required on the bottom brackets but already found that the holes on the inside of the van for this.
Just got to decide when to order one from now...
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
OK ordered the rack, 2wks to get it in so a job for a few weeks times. Will update.
Ridgeway
3,653
6,145
Lausanne
NiBi Arto 85E
Since 2012
The deed is done ! 6.5mm holes, 6mm bolts and a tube of Sikafix later and we have a windy down bike racky thingy m'bob.
Have also added the 2 additional quick rails so it can handle 4 bikes, nice n'easy !
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This picture illustrates Rapido design stupidity and why I ignored the mounts that dealers will use.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Found an appropriate picture of mine as it should be. No signal board as not required for this journey.
Even without a bike cover Rapido fixings cause the lights to be obscured. They are somewhat lacking in the responsible department.
