Rapido Alloy Wheel Bolt Release Socket
Discussion in 'Fiat' started by Sheddy, Nov 26, 2014.
  1. Sheddy
    Sheddy Funster
    Oct 20, 2010
    894
    3,340
    Burry Port South Wales / Benidorm
    Been trying to get a replacement female lock socket for the Alloy wheels on my new van.
    I have been advised by Rapido in France that they are AL-KO items, contacted AL-KO they say they do not supply wheel bolts or sockets !!
    The normal bolts are 16mm thread with a 19mm head, the locking bolt head is also about 19mm diameter.
    Photos of the wheel and bolts.
    Any Idea where I can get a replacement socket, or alternative would be welcome.
  2. jaygee
    jaygee Funster
    Mar 21, 2009
    1,168
    721
    Harwich, Essex
    The socket and theft proof wheel nuts come in a kit, as far as im aware the socket is not available on its own,if you loose the socket then its remove the old nuts which can be quite a job.
    We come across this quite often in the workshop and we use a dedicated impact tool to remove but sometimes it can be more troublesome.
    Have a good look around vehicle they are often hidden,spare wheel,tool kit area could be anywhere as we have often found
    HTH
    • Like Like x 1
  3. Al-Di
    Al-Di Funster
    Mar 15, 2014
    953
    3,450
    prestwich
    • Like Like x 2
  4. Brian and Jo
    Brian and Jo Funster Life Member
    Sep 24, 2007
    2,111
    4,039
    oswestry,shropshire
    Hi there,that is the security bolt and it does look very worn.if that was mine i would get a slightly smaller socket,hammer it over the bolt head and remove it and fit an ordinary bolt in place and then remove the rest and do the same.or you could go to any motor factors and buy a new set of security bolts.but you never hear now of wheels getting stolen,they just take the vechicle:eek:.but if they are not in good condition the security bolts can be a right pain.just my opinion for experience in the workshop.
    Brian and Jo
    • Like Like x 1
  5. Sheddy
    Sheddy Funster
    Oct 20, 2010
    894
    3,340
    Thanks, got one of these from fleabay did the job very well, thanks for the help (y)
    • Like Like x 4
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,688
    5,837
    Mansfield,Notts
    So have all the scrotes so dont bother with the expense new ones;)
    • Like Like x 2
  7. SteveandDenise
    SteveandDenise Funster
    Sep 26, 2011
    509
    652
    Spalding LINCS
    We have a Rapido with a similar locking stud but not sure if it will be the same fit, if it is you are welcome to try it at a rally if it dose the job you could remove the studs and replace them with ordinary studs. Alternatively, you can have ours and give us the standard studs.
    • Like Like x 1
  8. Sheddy
    Sheddy Funster
    Oct 20, 2010
    894
    3,340
    Thanks for the offer, but I have now replaced the old lock bolts with replacement standard ones, so good to go now.
  9. sadlonelygit
    sadlonelygit Read Only Funster
    Jan 28, 2014
    155
    95
    forest of dean
    in future, get a gator grip...........it's what the scrotes use!
    • Like Like x 1
