ramps (1 Viewer)
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
Having struggled with my little Fiamma levelling ramps on a few occasions and then reading recently about some breaking I thought I would bite the bullet and get some Milenco Quattro's as recommended by all and sundry, the best,strongest ramps on the market.
They arrived this morning,well packaged and marked. FRAGILE:ROFLMAO:
fills me full of confidence!!!!:Eeek:
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
I may be wrong, but the Fiamma ramps that broke were the black Maxi-Level type. Big ones similar to the Quattro but with only three steps up.
One of mine completely snapped in two between the first and second level.
I now have a pair of Quattro's and they seem a lot more substantial than the Fiamma ones. Time will tell.
I still have a pair of the smaller Fiamma levels, the yellow ones, and they are not showing any signs of failing. The only reason I got the larger ones was because they gave a lot more height for levelling on sloping pitches.
Chris
21,051
278,576
None
10 years
I need to get some bigger ramps too. I only have the small Fiamma ones.
We stopped on a pitch in France last week using the little ramps and it was an uphill walk to bed.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
It was my yellow ones that started to split, a left over from our caravanning days. The Milenco ones have done us well in the last 18 months and show no sign of cracking and we have used them a lot. Mind you, when we are on the top level it's quite a step up into the van, my dog has a bit of a struggle getting in!
Rgds Bill
May 7, 2011
4,808
47,493
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
Hi , I personally use Milenco Quattro ( The best ) I also take 1 yellow fiamma for the third wheel ,so far have always got 99% level where ever.
May 8, 2011
3,863
48,476
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
I got the same ones this week, must have been from the same company:ROFLMAO:
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
I screwed a chamfered block of wood to the bottom of mine. It adds about another two to three inches to the height. Works a treat.
g8ysn
638
417
ng219ep
coachbuilt
g8ysn
tried ramps but had enough of em breaking plus being auto it does,t like them
now use 4 millenco caravan levellers. stop if not level slide under lower wheel/wheels level up at leisure, did a deal on all 4 from lowdem,s £250.00:Eeek:
tinkering
222
1,105
dorset
C class
Since 1972
I have had two pairs of ramps since 1978:thumb:
Two pieces of wood 2'x6''x3'' and two smaller pieces 1'x4''x6''.
They all fit in the gas locker.
The cost me a pint ( the wood came out of a builders skip).
£250 quid for four devices the mind boggles:ROFLMAO::ROFLMAO:
Les:winky:
May 13, 2012
383
171
West Mids
Bailey Advance 6-2
since 2012
Wouldn't three be the most you would need?
mikebeaches
5,393
8,595
Bristol
Rapido V68 Van Conversion
Since 2009
Have had Milenco tripple levels for some time now. Although they do not lift quite as high as the quads, they are much more compact and weigh less too. They generally work OK for us. :thumb:
Surprisingly, on our last 4-week trip to France, where I think we stopped over in about 15 different places - quite remarkably we didn't need to use levels once!:winky:
Mike
francour
94
13
Pontefract
a class
since 1990
Hi I just got set Thule ramps £25 5 ton weight limit the small ramps are for caravans no good for motorhomes to heavy Bernie:Smile:
Aug 18, 2011
12,135
18,001
derbys
AUTOSLEEPER SYMBOL
YOU WASTED YOUR MONEY ON 4. YOU NEVER NEED MORE THAN 3. BUSBY::bigsmile:
g8ysn
638
417
ng219ep
coachbuilt
g8ysn
u r probably correct re- only needing 3 leveles. i,m the type if i think i need it i,ll buy them it my wife is disabled i have to sort van,canopy/safari room etc myself so i try to make things as easy as possible, as stated re- towing a car-etc behind you,r van . u do what u htink is best 4 u
c you,r point re-3, i try 2 take on-board relative constructive information:Eeek:
MHVirgins
3,889
3,158
South of Scotland
March 2011
It's even worse "downhill" for us after a few glasses of the red stuff!!:roflmto:
Margaret
oldun
747
162
St Neots
VW Campervan
Since 2001
I had two problems with my small Fiamma ramps.
1. They bowed under the weight of the van and then started splitting
2. The cheese grater design for the underside meant that they sank easily into the soft ground
The Millenco ramps are far better made and far superior.
