Raising the roof! (1 Viewer)
paul8ch
76
52
kent
minibus conversion
I'm a newbie
This might sound a little stoopid but I have built in a full size bed in my ldv convoy.It's about a metre from the floor with the worlds thickest mattress! Trouble is wifey feels a bit closed in being so close to the roof.Has anybody here ever raised a roof on a panel van/minibus? I'm more than capable of carrying out the work myself to quite a high standard as this is sort of my trade but it would be nice to see some pics so I can show Mrs H what to expect.I am only raising the rear 5/6 foot by about 12".Should think it will look a bit of a weird fish but hey ho owners and their dogs and all that!:Eeek:
Apr 27, 2008
11,788
13,942
Eastbourne East Sussex
Hymer low profile
Since 1972
Wouldn't it be easier to lower the bed :Smile:
There used to be some companies that would cut a chunk out of the roof and fit a fiberglass hightop, though I last did this in 1977 so things have probably changed since then.
Like this Link Removed
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
just cut a big hole and seal,rivet then fill a fibreglass pod on top.
best way of showing Mrs is take a picture of the van as it is then get someone to photoshop you a pod on top then show the mrs that one.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yes fitting hightops was easy .cut the hole . rest new roof on the top . clamp strips of wood into the gutter . go inside spoon adhesive into the little trough . wait a few hours . remove wood and off you go. we fitted sheldon hightops and then went on to leisuredrive roofs . have a leisuredrive proto type here on my sons vw. been on since 98.
yes you could just make a fibreglass bit for what you want . or maybe make it in ply and resin coat it. . or look for a vehicle in a scrap yard cut off the area you need and make a front or back to suit.
anything is possible .have seen vans with beetles on top as a high roof . or mercs with citreon 2cv.s as extentions .
could be a cut and shut using alot of the original roof .but might be hard to fold in situe .
you could make a steel pod and weld rivet, glue it in place. the world needs ideas to get things going. if you are confident you can . then do it.
lunarman
2,147
2,438
South Glos
since 1994
Link Removed
Autocruise have done the same on their starblazer to give more headroom over the garage bed.
Lunarman
