radio shut down
Discussion in 'Tech/Mech General' started by mick, Nov 17, 2008.
  1. mick
    mick Read Only Funster
    Apr 6, 2008
    23
    middlesex/ mojacar spain
    hi all
    can anyone tell me how to by pass the factory fitted radio cut out on a peugot swift. it will only stay on for 20 mins, unless i leave the ignition switch on. dont like to do that. any advice. thanks
    mick
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    hi mick,
    i have the same problem with my works citroen van but it lasts 30 mins....just long enough for lunch break. :Rofl1::Rofl1:
    i think the only way is to trace the auxilary feed wire from the radio back to the fusebox and move it to a different fuse, again controlled by the accessory position and of the same rating.
    not sure but there could be a capacitor in the radio feed circuit, or radio itself, giving enough power for 20/30mins only.
    if its in the radio your stuck with the time limit or change the radio.
  3. dshague
    dshague Funster
    Aug 22, 2007
    916
    187
    sth yorks
    on my 2001 Fiat there was a permanent live yellow wire you could use this and then switch off on radio.
  4. pappajohn
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    did that on my car but found the radio was drawing 172mah when turned off (memory and part circuit live), which flattened the battery if stood for a couple of weeks.
    after connecting properly it was drawing 9mah (memory only)when turned off .
  5. dshague
    dshague Funster
    Aug 22, 2007
    916
    187
    sth yorks
    ohhh :Eeek: then its off to auto electic man :cry:
    sorry my post was wrong then . :Blush:
  6. pappajohn
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    hey....not a problem.:thumb:
    i only found out 'cos i did it.
    couldnt figure out why my battery was going flat.:Sad:
    this was an aftermarket replacement radio in my corsa (the old one was locked out..£30 to unlock it. vauxhall radio...not worth £30) so it may just have been this one incident:Doh:
  7. ArenqueRojo
    ArenqueRojo Read Only Funster
    Nov 10, 2008
    261
    Anywhere in Europe, so fa
    Just cut the yellow wire. Power is supplied on red and black.:thumb:
  8. pappajohn
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    so the yellow wire feeds the timer then ?
    BTW.........welcome to the fun site
  9. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,579
    3,383
    Telford, Shropshire
    If this is on a new X2/50 type 'van then the only solution I know of is to change the radio for a different make, the factory fit unit is triggered via the can bus system. If its the previous generation then yes it can easily be bypassed, I'll try to find a diagram I did for another forum a bit later.
    D.
  10. mick
    Apr 6, 2008
    23
    i'm sorry if people have seen this before only i cant seem to log in to motorhome chat. can anyone tell me how to stop my radio cuts out after 20 mins when the engine is switched off. i have to put the ignition on to hear it constaintly.
    thanks
    mick
