radio reception
Discussion in 'Tech/Mech General' started by freelanderuk, Nov 24, 2011.
  1. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    been having trouble with radio reception and found that have no aerial so i have bought a amplified Ariel to try( sticks on the screen) this needs a power supply ,
    my radio is wired so that i can use with out the keys in the ignition , my question is where can i get a switched feed from the radio for the amplifier so that it turns of when i turn the radio off, would the feed for the electric Ariel on the back of the radio do it
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    hi on the back of the radio there will be the electric aerial wire (normally blue on most sets)
    this will be fine to power the stick on aerial.
    there may also be another switched feed for amplifiers depending on the make and type of radio this is also normally blue but sometimes has a white stripe this has a slightly higher capacity but does the same job.
  3. freelanderuk
    Sep 24, 2009
    1,022
    541
    thanks , have been out with the multimeter and the blue wire as you said has a switched power supply , all done and fitted lots better:Smile:
