RADIO FIAT DUCATO 2011
Discussion in 'Tech/Mech General' started by musson, Aug 1, 2014.
  1. musson
    musson Funster
    Dec 25, 2013
    418
    143
    grantham
    just wondered if anyone has had a issue with the radio reception
    when the MH is stationary works great but on the move it is no use cannot get hardly
    any stations,the dealer has just fitted a new unit,still the same I am taking it back again
    any suggestions
    Paul
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,203
    1,922
    London
    We have a 2012 Fiat Ducato based motorhome with the Autotrail media centre.
    Absolutely useless as a radio.
    We have never used it since we tried it on the very first journey when we picked it up brand new.
    • Like it Like it x 1
  3. The Dude
    The Dude Funster
    Jan 10, 2013
    2,580
    2,572
    Near Uttoxeter and Crete
    Same for us with 2010 Autotrail on a Fiat Ducato. We always take the IPOD as the radio is so useless. Had a Autocruise on a Peugot Boxer before and radio was fine. Don't really understand why there should be such a difference but there is.
  4. TheDentons
    TheDentons Funster
    Aug 7, 2013
    259
    155
    South Wales
    2011 ducato with a blaupunkt radio which was rubbish replaced it with a kenwood problem solved
    • Like it Like it x 2
  5. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    177
    112
    Ebbw Vale Gwent
    Hi Paul
    Yes I too have the same problem, haven’t sorted it out yet but I will get to the bottom of the problem, however my first throats are to lead me to believe that it is possibly the aerial on the roof or even a bad connection on the coax cable.
    Regards
    Ray
  6. Manxcat
    Manxcat Funster
    Jun 22, 2011
    118
    144
    Isle of Man
    The answer seems to be that the "standard" aerial is inside the wing mirrors and is useless. We paid £800 for a fancy Blaupunkt New York system (very good), but the radio was completely useless. A local specialist fitted a "proper" aerial and all is now well.
    By the way this cost about £140 for fitting professionally.
  7. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    6,018
    12,189
    Kettering
    Same problem here as well. Great reception when engine off, horrible static with engine on. It has a roof aerial, it has a suppressor fitted and the metal case of the radio unit is definitely grounded. Any ideas?
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,298
    3,102
    Kendal, Cumbria
    I assume you are listening to FM stations? If so an incompetent installer has to try really hard to enable you to hear interference. I have never seen a decent dealer installation of a radio or aerial on any MH I've owned. My new-to-me Hymer is a case in point: the original aerial is a Calearo which has a splitter inside the vehicle just behind the aerial itself. The splitter has two outputs - one for FM radio and the other (not connected & hidden behind the dashboard) for digital television. The aerial is within 25mm of aluminium bodywork over 2/3 of its length. It isn't earthed to the bodywork but has a separate 2.5 sq. mm wire running from the base of the aerial, inside the vehicle, to the chassis. There are so many things wrong with that installation I don't know where to begin .................. well I do actually - I replaced the whole lot.
