Radiator water top up
Discussion in 'Motorhome Chat' started by durhamahoy, Aug 11, 2013.
  1. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Hi,
    We have had our 2001 van for a month now and covered about 1200 miles on several trips out and thoroughly enjoy the motorhome way.
    Question I have got and which was not a problem on our previous van is the water level has dropped to the 'Min' for the radiator and has required topping up twice? is this normal? or has there been some evaporation due to the warm weather?? or have I got a leak on the system.
    The engine is a Peugeot 2.5 TdI Diesel. Any advice much appreciated.
    Steve
  2. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,047
    3,448
    walthamstow east london
  3. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    a sealed expansion cooling system should not need topping up under normal circumstances . you are more than likely suffering water loss due to either coolant leaking externaly ie hose,water-pump , radiator etc or more seriously coolant being burnt off internally, due to a weak headgasket . expansion bottle caps are sometimes prone to fail and this can depressurise the system thus letting the coolant boil off . if a visual check of the system cant spot any traces of anti freeze, then your best option is a pressure test at your local garage . regards garry
  4. ehuplad
    ehuplad Read Only Funster
    Feb 9, 2009
    509
    93
    North Yorkshire
    Does it ever go below the min mark??
    Sometimes they find there own level, if it does not loose any when on min then it is ok.
  5. greyman1
    Aug 7, 2011
    363
    273
    manchester
    just remembered, i think that engine has a metal coolant pipe that runs along the back of the engine block and it can corrode through near its mountings ! people some times miss it because the coolant doesnt drip onto the ground it gets collected in the castings of the engine block and then burnt off when the engine is running . garry
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,356
    9,801
    check the underside of your oil filler cap. if theres a sign of white gummy residue, your headgasket is likely starting to leak. topping up the level twice over a few months is a fairly slow leak. look at all the joints and check for staining. they may not appear wet as they may just leak under pressure with the engine running
  7. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Hi,
    Have not found that out yet have topped up before it has stayed too long on the min mark
    Steve
  8. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Next job will be to do just that.
    Thanks for the advice
    Steve
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    you have a leak.
    have the system pressure tested and the leak fixed before it gets worse and possibly blow the cylinder head gasket.
  10. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Ouch, will get her pressure tested for sure. Only had the van for a month from a dealer so think warranty ?
    Steve
