Rad fans not switching off!
Discussion in 'Tech/Mech General' started by mikekaren2, Jul 23, 2015.
  1. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Well we are on day four of our escape to France, we have just arrived at Talmont T Hillaire & now the radiator cooling fans will not switch off, even with the ignition key is removed. The battery is being drained so after an hour I have disconnected the main battery. I am on site for 7 nights so no immediate panic. Has anyone got an idea what the cause could be? It's a 1999 Hymer 2.9 TDI diesel Fiat Ducato maxi chassis. If you suggest a part eg thermostat give me a clue where to look.
    Mike
  2. buffallobill
    buffallobill
    Sep 21, 2013
    58
    46
    skipton
    There is a 2 relays in a plastic cover near the top of radiator these are for the 2 fans . On our 2.5 fiat only 1 fan ran . The 2nd fan was for really high temp. The relays are about
    25 mm square. I think your 1st relay as stuck. Pull the 2 relays out of the pin sockets and put the 2nd fan relay into the 1st fan pin plug I think that will stop the fan continuously running, then renew when you get new relays from a auto electricians, hope this helps.
    • Like it Like it x 2
  3. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Thanks for the reply Bill is it possible to show in a photo where I need to look, no rush but it would help if you have access to take a photo.
    Mike
  4. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    437
    409
    Lincs
    • Like it Like it x 1
  5. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Yes that looks good, I can see the cover now, does anyone know how it is removed, clips, screws, or just pull? I don't want to break it.
    Mike
  6. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Bump
  7. 2bob
    2bob Funster
    Jul 8, 2008
    619
    337
    dorset
    if not that/// i go for water temperature switch /another way is pull wire off the switch to stop fan
  8. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Ok I have removed the relay cover (2 screws) there are 3 relays two yellow & one black just waiting for the battery to reach cranking charge so I can test the relays, I am assuming that the two yellow ones are for the two fans.
    Thanks for all of the replies.
    Mike
  9. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Hopefully I am now sorted, I have swapped the relays over and used silicone grease to clean the contacts. Ran the engine while in situ & all seems well. The real test will be when I leave site on Thursday & have a proper road test. Thanks again for all of the advice.
    :inlove::dance:
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,929
    YO11 2BD
    Keep an eye on the temp in case the lower temp fan DOESNT kick in.
    No reason why it shouldnt but a glance is cheaper than a cylinder head gasket.
