Quick release battery clamps
Discussion in 'Motorhome Chat' started by davidbaldam, Aug 18, 2013.
  1. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    2,983
    7,238
    Market Harborough
    I thought I would fit a pair of quick release battery clamps to my van to save the battery draining between trips, I keep in a secure compound about 12 miles from my house. I fitted the negative one without any problems, then remove the battery to get at the positive only to find that there appears to be two cables as well as another small lead connected to it. The smaller lead I believe might be the alarms positive cable, which I could connect to the quick release clamp with a screw, the problem I have is how do I connect the two positive cables ( one of which could be the leisure batteries live cable) to the quick release clam, as I'm not sure they will fit in the clamp bracket. Any suggestions ?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    maybe need to change them for the type in the link...ignore the fact it states Mercedes, they are the same for many cars.
    longer bolts could be used, if neccessary, to make the gap large enough for dual cables.
    alternatively just fit the one that does fit to the neg terminal....you dont have to isolate both pos and neg as once the circuit is broken by one terminal the battery is no longer connected
    http://www.amazon.co.uk/Quick-Release-Battery-Clamps-MERCEDES/dp/B00BHHLI06/ref=sr_1_37?ie=UTF8&qid=1376847690&sr=8-37&keywords=quick+release+battery+clamps
    • Like Like x 2
  3. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    2,983
    7,238
    Market Harborough
    Thanks for that pappajohn, didn't think about only using one quick release clamp, thought you had to disconnect both, thanks again.
    David :thumb: :thumb:
    • Like Like x 1
  4. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Most quick releases are for the negative terminal only. The positive terminal is actually slightly bigger and normally it won't even fit.
    • Like Like x 1
  5. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    have to disagree...most are sold as pairs...one red for pos and one black for neg.
  6. hilldweller
    Dec 5, 2008
    26,920
    25,766
    Macclesfield
    Why 2 clips ? One will disconnect the battery.
    Does your secure compound get sunlight ?
  7. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    2,983
    7,238
    Market Harborough
    Hi Brian
    Yes plenty of light, tried a small solar panel the type you stick on your windscreen, which I thought would do the trick but last winter my battery when flat. As I've fitted one clamp to the negative then I will go down that route. Can't afford a roof solar panel yet. David :thumb:
