Questions: gas & fridge
Discussion in 'The Beginner' started by Sift, Apr 24, 2014.
  1. Sift
    Sift Read Only Funster
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Probably silly questions but start as you mean to go on:
    - Is it correct to assume that it is ok to leave the gas on at all times, even when travelling, and that it only needs turning off at the tap when you're not using the MH for a while?
    - Can the fridge be run (on gas) while travelling?
    Apologies if these are really basic questions. I will try to find something more challenging in due course.
    Regards,
    Lee.
  2. sticky130
    sticky130 Read Only Funster
    Sep 30, 2012
    108
    88
    Frampton, West Dorset
    Well being relative newbies ourselves this is how we see it.
    We run the fridge on the battery setting when travelling as we were under the impression that the gas cuts out anyway when moving, also battery power free :thumb:
    We have fixed gas tanks which we are supposed to flick off when moving, its a switch next to the panel indoors so we should remember but we never do :Doh:
    we only ever run the fridge on gas if we're not on hook up.
    hope this helps :BigGrin:
  3. Abacist
    Abacist Funster
    Oct 15, 2013
    1,282
    1,521
    Devon
    Gas on during transit is a no-no!
    No this is not on on safety grounds.
    Fridge running on gas has a lit pilot light and therefore in an accident could ignite fuel or gas vapour to cause an explosion.
    I expect it is or ought to be illegal!
    Why can fridge not run on 12 volt system as battery is being charged by vehicle alternator?
  4. Sift
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Thanks all. Fridge probably can run on 12v just didn't think about that. In fact it will probably auto select (with any luck).
    Regards,
    Lee.
  5. OddSocks
    OddSocks Read Only Funster
    Apr 10, 2014
    479
    395
    Cornwall
    Also a newbie, but here is my understanding.
    Always turn off the gas at the bottle before travelling for safety reasons.
    Switch the fridge to the 12volt setting while you travel, as it will be fed by the main battery which is kept topped up by the engine, so it does not cost you any power.
    I was told that as soon as you stop and turn off the engine, the fridge will stop operating on the 12 volt system, in order to preserve your engine battery. This is when you can switch to 240 if you are hooked up, or turn on the gas and use that.
    :thumb:
    • Like Like x 1
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,832
    3,337
    Eastbourne East Sussex
    I beleive most RVs fridges don't run on 12v and so are always run on gas when moving, so it's not a total nono. However best to run on 12v when moving, and a fridge running on gas would be a hazard when refuelling.
    • Like Like x 1
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,535
    1,421
    West Midlands
    One point worth making. I was not aware of this until we'd had the van a while. When not using the van, and therefore the fridge, for any period of time, the inside of the fridge would start to grow mildew, due to closed door + no refridgeration. Now aware that door catch has an 'ajar' setting to prevent this. It is not obvious but fiddle around a bit and you can close door catch into the 'slightly open' position.
    Wyn
    • Like Like x 1
  8. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,579
    5,668
    Near Mold North Wales
    Don't forget SecuMotion.:thumb:
    • Like Like x 2
  9. Sift
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Thank you. I had to look up Secumotion. I do not have this installed (but now on the list) so I guess the safest option is to either turn the gas off while driving or (more likely) turn the fridge off while refuelling. Cue warm beer on arrival.
    Cheers,
    Lee.
  10. beerdrinker1
    beerdrinker1 Funster
    Mar 18, 2012
    635
    720
    Loch Lomond Scotland
    Is that having a dump whilst safely seated Phil ?,
    :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
    ::thumb: drink::drink::drink:
    • Like Like x 2
  11. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,796
    You may know this already but run the fridge on gas for a few hours before driving in order to lower the temperature inside. The 12 volt system will only really 'maintain' the fridge temperature as it is.
    :Smile:
    • Like Like x 1
  12. scotjimland
    Jul 25, 2007
    28,934
    25,602
    correct.... and agree
    our RV fridge/freezer had no 12 v option..
    Probably due to the physical size of the freezer.. they would need big wattage heaters using a lot of amps.. or maybe it's just to save cost..
    When on driving in winter we also ran with the space heating running ...
    There are lots of things that are considered dangerous, or you are 'not supposed to do' on the move ...
    passengers using the toilet , making a sandwich.. and even going to bed for a kip.. leaving fridge on gas while on a ferry.. refueling etc .. we've done them all.. some deliberately.. others due to forgetfulness.. still hear to tell the tale..
    I've even heard of a slow cooker being used on the move .. :Wink:....
    If you have a working 12v option use it.. and as said, cool the fridge down to operating temperature before the journey with either gas or 230v.. also have the fridge as full of food as possible..
  13. carolyn
    carolyn Funster
    Jun 22, 2012
    694
    1,640
    Sherborne Dorset
    Don't assume the 12v goes off automatically when you turn engine off, ours is a 2003 autosleeper symbol and unfortunately it does'nt as we found out to our cost when we forgot one time.
    • Like Like x 1
  14. scotjimland
    Jul 25, 2007
    28,934
    25,602
    The fridge 12v should not be on unless the engine is running... it should be fed via a relay, normally on the same relay that closes to charge the hab battery from the alternator..usually referred to as the 'split charge' relay..
    Sounds like it is either faulty or hasn't been installed, which is very doubtful..
    have you had it checked ?
  15. carolyn
    carolyn Funster
    Jun 22, 2012
    694
    1,640
    Sherborne Dorset
    Thanks Scitjimlad, I will ask my local garage man when van goes in for its service, he will understand even though I don't. Electric is a bit of a mystery to me.
  16. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    421
    393
    Lincs
    Carolyn
    I used to have this problem - the fridge would carry on running on 12v even when the engine was switched off. The leisure battery wasn't in the best of conditions when I bought the van last year and I managed to kill it off a couple of times too by forgetting to switch the fridge from 12v to gas.
    I replaced that battery last year and not wanting to destroy it stopped using the fridge on 12v.
    However - last week I finally solved the problem:BigGrin:
    On the electroblok there is a space for a fuse for the fridge, but by this space is a great big warning triangle with an exclamation mark in it and the wording 'Fuse only with AES fridge'. Now, my fridge is not AES (which is auto source sensing) so I removed the fuse and voila! The fridge now runs as it should do and switches off from 12v when the engine stops.
    I don't know how autosleepers are set up, but if it's a similar system it may be something as simple as a fuse that shouldn't be there, so it's worth checking.
  17. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,186
    1,284
    norfolk
    Congratulations on your choice of transport, the 250 MZ Racer!, top class :thumb:
    • Like Like x 1
  18. Sift
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Will be up your way, at Snetterton, tonight. Watching, not racing though.
    Cheers,
    Lee.
  19. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,186
    1,284
    norfolk
    Hope you have got your wets with you!
    • Like Like x 1
  20. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,082
    8,173
    Forest of Dean
    Like Jim we've done all the above and as ex RVers we always ran with the fridge on gas and the gas heating on in the winter in 3 RVs over 100'000 miles still here and never blew up ourselves or anything else. For the last 3 years we've owned a Hymer which thankfully had a Secumotion fitted so we still travel with fridge on gas and heating on its lovelly :BigGrin: oh and we occasionally have the Remoska cooking as we go along.:Wink:
    Seriously though we do always turn the gas off as we enter fuel stations and never enter the pumps with gas on. :thumb:
