Question on poor oven in motorhome (1 Viewer)
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
We have just had our first trip in our hew motorhome and love it but the oven is very very slow (gas) took 45 mins just to take the chill off defrosted oven chips. We can see the flame is burning quite low.
The oven (no label or name discernible) is ten years old. (Like the van) Is it possible to have them serviced? If so where would I go or should I ring an oven engineer?
Any thoughts? Or should we just buy another oven? Any idea of the cost and who would fit it?
Still newbies I'm afraid.
Any help much appreciated.
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
This topic comes up a lot some supplied ovens are just not fit for purpose.
We spend months at a time in our van and do like to cook our own food especially roast meat n veg. We have a Smev oven which is fantastic our van is an 02 and its the original oven.
irnbru
13,512
31,137
Glasgow
Benimar 264
11 yrs
Ours was low but it was due to the fact we were also trying to use the boiler, the gas fire and 2 rings at the same time. Perhaps you were using too many items?
Feb 22, 2011
9,763
20,120
Newcastle under Lyme
Hymer B544 A Class
Since 2015
We have the smev oven. Don't think it was original specifications in the 2003 hymer so must have been added later.
It does take a lot longer to cook things but it gets there in the end although things do need turning as it gets hotter at back than front !
A service may help
Mar 29, 2011
961
639
Rugby UK
C Class RS
In our Hobby we have one of the small ones on top of the fridge freezer, in the paperwork its called warming oven, good description cos its crap, on the middle shelf it takes forever on the top shelf it burns the outside, due soon to collect a new to us van and its got a proper oven so I hope that works better
Scout
3,958
120,964
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
ours is very good, its 11 years old and really does the job...
do you have a good flame? might be worth running a hover over the (when cold) burner
are you using propane?
Apr 11, 2015
5,398
54,953
hull
Laika Ecovip 300
we have had ovens in both our vans, both excellent, but with some you need to put them on highest setting and get them really hot before putting the food in and turning them down. A service on a 10 YO oven would be a good move, no saying how furred up the pipes might be.
scotjimland
2,256
9,780
A Woosh bang
If the flame is blue but just low, that would indicate either a blocked jet and or low gas pressure ..
if the cooker burner flames are normal, then the pressure is probably ok, but should be checked.
have it serviced with a new jet fitted... at any caravan dealer or DIY
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Are you using Butane or Propane? I have SMEV in a B584. It isn't as quick as some but no problem to use.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
We had our oven taken out when we bought the van because our past experience was so bad. The budget Smev oven most German manufacturers seem to fit is awful. When we bought a new Hobby caravan a few years ago we found it took ages to get hot and took ages to heat anything never mind cook food. Had to buy a halogen oven in the end. Complained to the dealer who told us they were all the same and Hobby knew but were doing nothing. Buy a remoska and a baby generator
D
deleted-member02
We've had two smev ovens, last one was poor, current one better but not perfect.... we tend to double cooking times and regularly turn whatever's in the oven.
