Question for the GAS whizzos
Discussion in 'Motorhome Chat' started by laneside, Aug 3, 2012.
  1. laneside
    laneside Funster
    Aug 14, 2009
    3,609
    5,704
    Oradour sur Vayres
    Just getting ready for France in September and I need some help
    We have a French cube from a previous trip which was easy to connect to our Autosleeper but now with our Rapido it is all fancy with a built in regulator and solenoid switch
    The first question is if i can get a pigtail to fit the Cube regulator (which has to be in situ) and connect it to the in of the Rapido built in regulator will it give sufficient pressure to work?
    or will any French bottles that do not require a regulator on top drop in where a Calor one is now,assuming I can buy one ?
    or are`you sending me off for a Gaslow/Alugas set up?
    Thanks Alan
  2. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Alan get yourself a Butane /propane adaptor..female to male..that will save you by passing the auto shut off pressure valve..or if not you could get pigtail to fit your set up (from your bottle to regulator) then any french bottle will fit...you bottle area should take two 13kg bottles mine does
    One may be enough depending on how long is a piece of string ...no I mean how long you are coming for...I have just done this a MHF member he already had butane fittings so I gave him one of my bottles to keep filling up while in France....BUT sadly he has taken my bottle home with him, or you could have had that one
    If you are going to do a lot of different countries then yes I would go for alugas...because they are lighter .then you just use the adaptors..if not Gaslow
    The French bottle has the same connection as the UK butane bottle male external thread
  3. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,312
    3,687
    Lincolnshire
  4. laneside
    laneside Funster
    Aug 14, 2009
    3,609
    5,704
    Oradour sur Vayres
    Mel if all the plans come together we may well be over there for all winter and even venture down into Spain.
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,800
    4,086
    roche cornwall
    ebay about twenty quid get the eu adaptors as well.
    in spain its far cheaper to get a spanish bottle and exchange . the pumps are dearer. very often garages will let you haver a bottle or ask the gas bottle truck man/woman. about 10euro deposit.
    you can buy a 35mm spanish fitting to the french /old uk butane fitting for about 7 euro in the leroy merlin hardeware shops.
  6. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    I would go for alugas then.....that is what we did ....Dave Newal did ours...the best about your motorhome the new Rapido it has already most of the parts in situ.....that what Dave told us when he quoted for the fitting of Alum gas...take some photos of your bottles and gas regulators and send to Dave for a quote..
    Mel
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    If you contact an Alugas supplier then you can get a pigtail, even one with secumotion. The Alugas bottle is the same fitting as French bottles.
    • Like it Like it x 1
  8. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
