- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
Be assured all the correct answers are within this thread
nailed itMaybe my naivete is showing, but it seems to me that a lot of this thread is all about advising someone on how to make an adjustment that's just not needed.
My question is quite a sensible one based on your previous comments ... you don't use a reverse polarity connection it appears so therefore equipment in your MH could be running with it's polarity reversed and therefore when you think it is totally turned off it might still be 'live' and if it developed a fault and you touched it ... poof ... do you see what I mean now?I do not use a reverse polarity tester.. .. ( A misnomer, as AC does not have polarity)
not sure why you are asking, I have given my view on this many times...there are dozens of threads about it.. no need for yet another.
Before putting your lead away, double your long lead up, then it only takes half as long to coil, encourages you to unwind the whole length before plugging in and makes it easier to lay back and forth to use up excess..
I also asked, quite legitimately, if you use a continental adaptor between your hook-up cable and the bollard ... if so, how to you protect the joint from the weather?
Our continental adaptor is on a short lead so the connection is generally held off the ground. If for some reason it isn't I ensure it is lifted up so it won't be flooded if there is a sudden downpour. As mentioned earlier the connection is waterproof but I wouldn't want to immerse it in a puddle.I also asked, quite legitimately, if you use a continental adaptor between your hook-up cable and the bollard ... if so, how to you protect the joint from the weather? Or are you going to tell me that you carry both a full length English and full length continental electric cable so you don't ever have to do this ...
Don't put a bag around it - bags tend to let water in in heavy rain and don't let it out. Although joints are frowned upon (and you may be asked not to use one on some Club sites) they're OK if a cover is use. You also need to be sure they aren't where a puddle might formSo long as you put a waterproof bag securely round a join it will be okay, or you can actually buy coupling covers anyway.
We cut ours into 2 lengths, one is 2/3rds the other 1/3rd.
You are correct and the fella is wrong about overheating. However all cables do have resistance (if they didn't they wouldn't get warm when coiled up).So in general its not a great idea.
What I have done for now is wind up from one end to half way and cable tie the loop so it stays neat and tidy together. Then I did the same from the other end and cable tied that up the same.
So if I need just half I just undo one half. If the full length is needed then I undo both loops.
But a fella on a site down south last weekend said leaving cables looped up would cause a resistance and knacker them. In 40 year in construction I have never heard of resistance in electric cables. I have heard of wound cables overheating but only if a lot of power is being drawn through them. With many sites having a limit on drawn power I cant see that happening ? But cables are not my specialty
Would it not have been easier to say "half The National Grid"?You can never have too much cable.
I just checked mine.....2 x 25mtr....1 x 30mtr....1 x 10mtr....a short tester lead....a 3 pin plug to euro socket lead....a euro plug to uk 3 pin socket lead and, from my early motorhoming days when i worried about such things, a reversed polarity correction lead.
Weighs a ton.
Weighs a ton.
I'll continue to live in the 'real' world where everything isn't perfect and continue to ensure that if I ever have to join two electric cables together and put a plastic bag round the join will be so well sealed to prevent water getting in that it could probably be used to send power down to a submarine!
The standard 16A connectors are IP44
4 Protected against solid objects up to 1mm. (eg Most wires, screws, etc).
4 Protection against water splashed from any direction - limited ingress permitted.
No, you are quite right. A problem only arises if the wire is tightly wound around a reel or drum and there is a heavy load such as a fan heater running. A dozen or so loose coils lying on the ground and a normal load won't cause a problem and shouldn't be under a high load either although you might want to keep an eye on it.I'm no expert but surely with the low amperage and current draw used by most motorhomes who use a cable purchased and designed specifically for the job, leaving it loosely coiled outside shouldn't be much of a problem.
We've done it for years and because of threads like this I've often checked our cable and never had a problem of it being hotter than expected considering the ambient temperature.
Also, I've never heard of anybody who's loosely coiled their cables in this fashion having had a problem. . . . . . . . . . But what do I know?
. . . . . . . . . Not a lot, but what I do know is that we spend around 3 months a year in the van and about 20/25% of that on hook-up and when parked at home the van is on hook-up most of the time and the excess cable is loosely coiled up under or beside the van and we've never had a problem
Depends on the bag I think, a Waitrose bag will be higher rated than one from Lidls.that's odd..
no definition for plastic bag enclosures in the IP ratings table .. (with or without holes)..
maybe an omission..
You're being over-sensitive to the comments in this thread. Most plastic-bag covered plug / socket joints I've seen around camp-sites (and building sites!) in wet weather have been half full of water and as such are extremely dangerous. Your method might be better than others but the point really is that provided the joint is clear of anywhere a pool might form it is safer to leave it uncovered than to seal it in a plastic bag. By all means cover it if you wish but leave the underside open so water can escape.You commoners!!!! To think that I'd use a shopping type plastic carrier indeed ... even a 'bag for life' wouldn't give any protection from water as they usually have small holes in, in case some tries to put it on their head! (Try it ... if you dare!)
Of course I'd use a proper bag ... like a high quality thick plastic freezer bag ... actually another reason for 'bagging' it is to make it more difficult for anyone to disconnect the 2 leads.
As I rarely go on sites, let alone use hook-up, there has only been one time when I ever needed to connect both cables together which was on an aire in France a couple of years ago ... and it was still too ruddy short!
