Pug X250 electrics (1 Viewer)
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
I am still something of a boy racer (albeit geriatric one) so I want to fit a pair of Angel Eyes Spots in the ugly holes on the front of our van. Really just to fill those holes. Don't intend a lot of moonlight flitting !
Question 1. - to have the "Angel"eyes come on with the side lights can I just splice into the side lights cable at the headlamp assembly ?
Question 1 a. Do I have to balance things and do each side separate ?
I have a separate little black box and wiring ("Ring" kit) for the main 55w Spotlights circuit with its dashboard fitting on/off switch.
Question 2. I seem to remember that I may experience a fault to appear, courtesy of something called Canbus or some other mickey mouse circuit systems phenomena. Or am I just paranoid ??
Jaws
23,830
72,328
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Nothing clever to do at all.. Just wire them in what ever is the easiest way for you :)
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If they are intended to be DRLs they must come on when the 'ignition' switch is turned on and go off when the sidelights are turned on.
C
Chockswahay
There was a thread on this a couple of days/weeks ago............. might be worth searching?
Moodybrook
Moodybrook
802
651
still in nappies
No, not DRLS' thanks, they are really just hole fillers/cosmetic, unlikely to be used in anger. Fog is generally an autumn/winter/spring, hazard, I don't do much bad weather, at least not intentionally. I do intend to do them properly however which is why I was asking for the benefit of your esteemed experience/knowledge. :)
