Pug Boxer Gear problem? (1 Viewer)
Elvis
294
45
London
Coach Built
Since Nov 2008
Well, we thought we had cured our seized gears with WD but no :Sad:
The 1st and reverse, went from very stiff to almost seized, we have heard that this is a very common problem with the Boxers. 5th gear can also seize but ours was fine.
Anyway, now cured! ::bigsmile::thumb:
After some internet research we bought a new 'control return linkage' £28 and paid £80 for it to be fitted (1-1/2hrs work) And now the gears are better than when we bought it! Yipeee! ::bigsmile:
I hope this helps people with the same prob as would hate to see anyone get conned into a new gear box or extra parts. But...please try the WD first as this can work (I am told) if the prob is not too bad but its very hard to get to the gear linkage so it's pot luck with the WD.
The photo below is the part that we needed to replace:
43,315
49,369
Mmm ! Nylon bushings and bearings....never did like 'em.
obviously the nylon wont rust but the metal will and the rust will swell and nip the coupling together.
i've had to bench press steel pins from nylon bushings before.
much cheaper than phosphor bronze but no where near as long lasting.
glad you got sorted. :thumb:
Oct 2, 2011
864
571
Scotland
Since 2011
What age is the Pug and what sort of milage had it covered when you first noticed the problem?
rainbow chasers
3,680
1,725
Mid Cornwall
Various
There won't be a hard and fast answer for that - gear linkages can fail as much through lack of use, as too much!
If a gearbox starts to fail as is common on these, it will first become noticable as being stiff first thing (when the oil is cold thus thicker) and the speedo needle will start to flicker.
Glad it turned out to be a cheaper fix!:thumb:
Elvis
Elvis
294
45
London
Coach Built
Since Nov 2008
He's 2003 but we bought him in Nov 08, My wife said the reverse and 1st were a little stiff since we bought him (I didnt notice it, at this point) and it gradually got worse over time. Last summer was when is became so bad that the van became almost un-driveable :Eeek: His millage when we bought him was about 3500, if I had listened to my wife then :Doh: I would have tried to have WD'd the part then, that may have avoided the issue, if I had done this each year but as I said, the part is very hard to get to, without a ramp and mechanical know-how.
Elvis
Elvis
294
45
London
Coach Built
Since Nov 2008
So true, it was because it was left standing a lot, it was much worse after it had been standing for a few months over the winter.
The symptoms were the same as you described above, except for the speedo flicker (well, I didnt notice that anyway)... I hope that does not mean the gear box may still go...:cry:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Just for you do you work in a chip shop?
[ame]http://www.youtube.com/watch?v=QccPUSTMriM&feature=related[/ame]
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You should be ok!
Get hold of some silicone grease, and grease the joints of the selectors. Silicome is a little more waterproof and won't rot the bushes.
If problem persist, then you could drain and refresh the gearbox oil as a precaution. If you do this, leave the old oil in a glass container overnight and it will seperate if water is present.
What i would advise, as it cost nothing to do, is check the scuttle drain and ensure that it exits BEHIND gearbox. Earlier models suffered with water ingress due to the scuttle drain dumping ontop of the box, just above the gearbox mounts.
All you need to do is ensure it is pushed back behind, and you can even add an extension pipe - some use old plastic tubing and secure behind the box. Prevention is the best cure as they say!
