Protecting Heki (1 Viewer)
Greenacres
82
13
Stoke on Trent
Burstner Travel Van t620
13 years since retirement and many younger years as a Hippy in a VW conversion, roaming the Greek Is
Is there a purpose made cover that can be bought to protect a heki from intense heat? Thought about making one myself then realised it would be difficult to put on. We peg towels on the side windows but the panoramic heki is always a concern.
Minxy
32,649
66,541
E Yorks
Carthago Compactline
I made a cover out of an old internal insulated windscreen cover, once I'd cut it to size and edged it I put 4 suckers through which hold it in place on the Heki, the bonus of this is that when we want the Heki open and it is sunny the screen stays in place, thus letting the air in but not the heat. Another advantage is that in cold weather it adds insulation to reduce the amount of heat lost overnight.
pegleg
71
26
cheshire
Low profile
12 years
Covers
Hi my first M.H. was a liaka and it came with a cover for the HEKI like MINX has made brilliant :thumb:
Greenacres
Greenacres
82
13
Stoke on Trent
Thankyou all. I like the cheap idea Minx using an old thermal cover. How do you reach the outside to stick on the suckers? Can it be done from the inside by threading the cover onto the outside?
Big 1 I'm afraid that the posh jobs will have to wait until I have saved up, but thanks for the link.
TheBig1
17,630
43,275
an ultra cheap version is buy one of those car windscreen protectors. they are like a hard foam or cardboard covered in foil (often got a picture on) and cut it down to fit under the skylight. normally see them in the pound shop
another option, but the same idea is reflective foil bubblwrap. again cut to size and stick to the inside using suckers, which are available on ebay for under 50p each
Minxy
32,649
66,541
E Yorks
It is stuck on the INSIDE of the Heki. :Doh::winky:
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Yes! Dometic have them. But they are not sold by many in the UK.
Broken Link Removed
The part numbers are:
Mini Hekiplus - 9103500008 Broken Link Removed
Midi Heki - 9103500009 Broken Link Removed
Heki 1-4 - 9103500010 Broken Link Removed
::bigsmile:
Minxy
32,649
66,541
E Yorks
Before sticking stuff to the inside of a Heki have a look here
Broken Link Removed
Third picture down on the first page. :thumb:
I suppose it depends on how tight a fit it is, the suckers make it 'stand off' a bit - I've used it on several MHs over the years (we had it originally in our Rimor, then our Chausson and now our Accent) and in all that time I've never had a problem. :thumb:
If not, then simply make a cover to go on the outside, but obviously it would need you to be able to reach to put it on, however seeing as it appears to be just a sheet of material with what look like 4 'hooks' on a piece of elastic cord I assume, one in each corner with which you attach it to the Heki, it would be easy peasy to make and certainly cannot possibly be worth the horrendous price asked for the 'official' ones! Maybe I should get my sewing machine out and go into business!!! :thumb:
Dec 6, 2011
11,589
25,417
South Wales
Coach built Adria
Broken Link Removed
::bigsmile:
at those prices im not surprised they are not for sale in m any places:Eeek:
Oct 15, 2012
10,190
57,440
Market Harborough
C Class Laika Ecovip 7R
We have a Laika and I thought everyone had the same as us which is a slidding cover that acts as a blind with an insect cover as well. :thumb:
TheBig1
17,630
43,275
the sliding blind and net are standard fit, but they dont have any noticable thermal advantage. the silver screen type helps keep the van warmer in very cold weather and cooler in bright hot sunshine
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Broken Link Removed
Have a look at my post (first quote) and the link, which I posted on page one of this thread. :thumb:
Minxy
32,649
66,541
E Yorks
Yes they do but in addition to what 'TheBig1' has said, if you want a good air flow you need to leave the blind completely open (just with the flyscreen across) to let the hot air out and cooler air (hopefully!) in but doing this will then let the sun in, hence the need to have something that actually goes on the opened Heki 'glass' itself.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
It would appear that Dometic are discontinuing the covers for Heki rooflights :RollEyes:
