Project request for information: Average size? (1 Viewer)
Feb 27, 2011
14,708
75,747
UK
Self Build
Of your solar panel install :xeek:.
I am just wondering what the average size of solar panels most people have. I know there are some of us who have 300-600 watts on our vans. And some have only 1 x 100 Watt panel.
But what is the average? If you can post your figure here it will give me a rough sample to base my project on.
Thank you :)
PS: fridge project is on hold until we have hot weather again, I am planning the solar project ready for the summer so I don't run out of the correct conditions again.
Gromett
Feb 27, 2011
14,708
75,747
UK
Self Build
PPS: I am working my nuts off on my day job to earn enough money so I can have next week off. This will then be spent making and editing videos so you can see what I am up to.
SandraL
1,373
985
Somerset
Hymer b694sl
250 watts total. One at 150 other at 100 due to space availability.
Abacist
3,711
10,547
Devon
N & B Arto 88F Tag
since 2013
3 X 100 + 1X 80 = 380 watts
D
Deleted member 29692
2 x 100 watt panels feeding 2 x 110ah leisure batteries plus whatever the cab battery is.
jnn
250
684
cheshire
van conversion trafic
nooby
2 * 100W for habitation plus 2*10W for van battery
(240ah + ?95ah)
MikeD
3,936
3,697
London
IH PVC
Since 2012
100w feeding 140ah battery - goes a bit low after four days in Spain.
Much quicker in UK I suspect
Brendan
371
12,632
Here there and everywhere
Since 2010
Fitted 4x80w to my last van.
Current van has 1x100w at the minute, but the plan was to see how that worked out before making too many changes.
I believe the controller will manage another 200w, so they will be fitted by spring.
Minxy
32,623
66,460
E Yorks
Carthago Compactline
1 x 60w semi-flexible solar panel and 2 x 95amp or 100 amp (can't remember!) leisure batteries.
What is the project you're doing though Gromett?
Feb 22, 2008
12,260
45,033
Norfolk
Nearly Tugging
Since 2004
120w and one 95a domestic and trickle feed to engine battery.
Gromett
Feb 27, 2011
14,708
75,747
UK
Self Build
I don't really want to say at the moment, because previous projects have dragged on for so long that they seem like vapour ware now :(
Needless to say, it is being designed by a motorhomer for motorhomers. I am designing it for my own use, but will open source all the software and hardware so anyone with a soldering iron can replicate it.
I have put the fridge project to one side until we get warmer weather. I am just planning the big project at the moment.
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
At the moment am running 2X100 watt into 330 amps of battery bank. Have not done enough touring with this van to tell if that is enough but in the past I have ran 300 watts into 450 amps of battery and could wild camp indefinitely with a small vertical axis wind turbine as back up.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Hi Karl, mine has 4 x 100 Watt solar-panels feeding a bank of 3 x 120 Ah leisure batteries and 1 x 105 Ah starter battery. All fitted as standard to the Frankia Platin Plus last year.
OZeRV
73
81
Cobram, 3644, Victoria, AUSTRALIA
Aust bus conv., UK C
Since 1995
600 watts solar (3 x 200 watt) charging at 24v into 4 x 120 Ah habitation batteries plus 2 x 120 Ah cranking batteries. Fridge/freezer is 210 lt 24v compressor type.
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
1x120watt panel into 2x110 hab batteries+tricle into engine battery.Not had a problem and we tour about 3 months at a time mostly wilding
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
2x80w feeding 3x110a batteries, but thinking of adding another 80w panel & maybe removing a battery?
