problems with water....
Discussion in 'The Beginner' started by Annie21220, Dec 20, 2015.
  1. Annie21220
    Annie21220 Funster
    Oct 21, 2014
    45
    26
    Malvern
    Hi Ive had my motorhome a couple of weeks, just trying to get to grips with all the tech issues...
    I have a carado t449... Ive filled the water tank, but no water is coming out of the taps, the dealer who i bought the motorhome of is away until 8th jan, so no joy there... any ideas on what i might be doing wrong.....
    Thanks in advance
    anne
  2. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,581
    14,133
    Scottish Borders
    I assume you have the electric on for the pump.... (sometimes the simple things trip us up), our water pump switch is on the electric control panel.
    Is the pump making a noise - you will hear it when it is running.
    If it isn't running you know the problem is at the pump or before.
    If it is running there could be an air lock somewhere.
    Someone else will be along with more ideas soon.
    Perhaps someone who lives locally will come and have a look for you :)
  3. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,875
    11,488
    under a wand'rin' star
    It took us ages to get this right - [1] switch on the electrics [2] switch on the pump (& cabin lights) [3] NOW the water & lighting will work :xThumb:
    Sadly we still get caught out by it quite regularly... :xblush:
    Luckily one of us usually remembers before we panic :xdoh:
    Hope your problem is as easily resolved @Annie21220 :xsmile:
    • Like Like x 1
  4. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,070
    6,618
    Spain for the winter
    Keeping the above suggestions in mind - if you have filled the tank, all the relevant switches are on and the pump is making a noise, perhaps your heater drain valve is open and all the water has run out again.
    This again is a common mistake, especially if parked on grass and you cannot see the huge puddle developing under your van.
    • Like Like x 3
  5. Annie21220
    Annie21220 Funster
    Oct 21, 2014
    45
    26
    Malvern
    Done it ,found the switch
    • Like Like x 2
