Problems with Bosch motor drive (1 Viewer)
Nov 9, 2015
156
244
North Hampshire
Hymer MC-I B 580
I have had my Kalkhoff Agattu i8 for getting on for 3 years and really like it but..... I was out recently in the rain and getting a move on but when I stopped pedalling the pedals were reluctant to stop and freewheel though if I stood on them hard they would. If I turn the motor off all back to normal but not with motor on.
I want someone reasonably close to Basingstoke who knows the Bosch system. I cannot see myself travelling to 50cycles the obvious people in Loughborough who supplied the bike.
Can anyone suggest a repairer? Note the people in Farnham who look really good will only look at their own customers bikes.
Eric
Dec 12, 2010
5,402
21,485
Cumbria
since 2011
The ratchet pawls on the crank have stuck in the up position. Complete strip down, clean and lube required. I did both our bikes last year and posted a thread and pics on it. Will try and find the thread. It's not too difficult a job if you have a modicum of mechanical ability (y)
G
Nov 9, 2015
156
244
North Hampshire
Hymer MC-I B 580
Thank you, I am prepared to have a go. Does it require any special tools.
Eric
Dec 12, 2010
5,402
21,485
Cumbria
since 2011
Can't find my post but here's a pic of one the pawls that caused my problem. The grease dries out and the free wheel pawls overcome the return spring and stick in the up position which won't allow the pedals to disengage.
I followed some info I found on the net that suggested forcing the pedals round, totally the wrong thing to do as I found out as it shattered one of the pawls, usually an exchange motor is the only answer to this situation, but luckily 50 cycles sent me two second hand replacements that sorted me out.
You can see the dried out grease/rust that causes the problem. When I stripped Val's bike, it was heading the same way. It's an awkward job, but should be done routinely a bit like a vehicle service.
Dec 12, 2010
5,402
21,485
Cumbria
since 2011
You'll need a jacking tool to remove the pedals, other than that, it's just torx screws. Here's a pic of the split crank case.
pm me if you need any more info.
travelling wilbury
94
38
somerset
Carthago Compactline i138
since 2009
failing that good advice....50 cycles also have a shop in Shoreham which might be a possibility?
G
Nov 9, 2015
156
244
North Hampshire
Hymer MC-I B 580
Once again, thanks. From your photos and description it seems to be my problem. Hopefully I did not do too much harm when riding home.
Eric
