problem with solar cables!
Discussion in 'Motorhome Chat' started by ultima, Aug 1, 2016.
  1. ultima
    ultima Funster
    Mar 24, 2010
    162
    61
    stoke on trent
    Just fitted my 80w solar panel and made entry in roof,I now find my cable ends on panel are too big to go through entry box I will be fitting on roof.Is it possible to remove ends and refit them once through roof or do I buy new ends and fit myself?
  2. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    775
    469
    Cornwall/France/Spain
    Why not cut off the ends, strip back the insulation and connect directly to the solar controller screw terminals?
  3. andyman
    andyman Funster
    Sep 23, 2007
    1,149
    506
    Leicestershire
    I have always cut them off and used snap connectors. It then makes it easy to add extra panels if needed at a later date.
  4. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    421
    393
    Lincs
    I think that I ended up cutting them off and fitting new ones. The ones that I cut off couldn't be refitted.
  5. johnandi
    johnandi Funster
    Sep 26, 2010
    291
    103
    North Wales
    I bought 5m Solar extension cables which have the 'plugs' on one end and nothing on the other hence making them easy to put through the roof and also long enough to reach and connect to the regulator.
    Biard Solar Cable 2 x 5m Solar Cable Extensions With MC4 Connectors For Caravan http://r.ebay.com/olklvq
    Use with these connectors:
    1 x Pair MC4 Solar Panel Branch Connectors IP67 1000V 30A TUV UK 2.5mm 4mm http://r.ebay.com/8rY3Vh
    John
  6. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,575
    7,155
    Plymouth
    Look on ebay for mc4 conectors as once cot off they're fubaru
  7. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,069
    1,472
    Dover
    If they are the proper connectors then they come off and leave just the sleeve the same size as the cable. You put it through the hole and rebuild them inside.
    • Informative Informative x 1
