prblem 2.8 fiat jtd engine (1 Viewer)
Jun 1, 2009
77
98
middleton manchester
coachbuilt
6 years
Hi can anyone technicle give me any sugestions to my engine problem.
there is some oil coming on to the top hoses of engine bay had a full service last week.
i am in spain and have travelled all the way mostly using my cruise controll no problems at 56mph,but on at tempting to climb steep hills the engine seems unresponsive to throttle.
Please be patient with any replies i make due to being on patchy wifi.
many thanksmin advance.
9
9526
Can you see where oil is coming from? (Have a look whilst ticking over but KEEP FINGERS etc clear)
For example is filter tight (going on recent service, which may be cause)
Is there enough oil in sump (quick dip if you've had a leak)
If you discover where oil is coming from it will be easier to diagnose potential issues.
Sep 17, 2014
86
91
swansea
a class rv
check no split on turbo pipe
bartiny
284
404
Accrington, Lancashire
Since 2008
This would explain the lack of power, but the oil??
I would hazzard a guess that the turbo waste gate is stuck (or not opening far enough) resulting in too much pressure build up in the engine, pistons struggling with the extra compression, lack of oomph extra "blowby" and hence the oil leaking.
I have just had the very same issue with my engine/turbo.
HTH(y)
Aug 6, 2013
11,941
16,527
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It could well be a split turbo hose. They're invariably coated internally by the small amount of engine oil that escapes the turbo oil seals. A wastegate sticking closed will cause an increase in power to the point at which the engine can't supply enough fuel for the extra air or the point at which mechanical failure occurs. A wastegate stuck partially or fully open will cause a dramatic loss of power.
bartiny
284
404
Since 2008
Sorry I do not agree with the above, it looks like you have been using Google for your answers, I am giving an answer/possible solution based on personal experience.
We are talking about a commercial diesel engine here, not a high revving sports car.
It is a common fault on these engines/turbo.
Am I 100% that the turbo is at fault, no but it is a 10 minute job and costs nothing.
It is possible that the engine is not getting enough fuel, but it is the oil leak that points me towards the turbo.
I am not going to argue the point with you, Lifes too short.
Sep 17, 2014
86
91
swansea
a class rv
I am not going to enter in to a debate with you, I do not need to Google anything, I have been in the motor trade for over 45 years, and was only trying to give advice for a possible cause to a fellow motor homer.
I cannot diagnose without seeing it.
yet you are 100% sure it is the turbo!
Reactions: f6c
bartiny
284
404
Since 2008
I think you be better read my post again, I did not say I was 100% sure, quite the opposite.
My response was not aimed at you, I did not quote you.
Exactly right, to try and diagnosing remotely is fraught with danger,( but like you) i also have many years experience in the motor trade, so I am not going to get into that one.
I was (like you) trying to give a fellow motorhomer my best advice/guess, as his problem mirrors my very recent (two weeks) identical problem, which was a stuck closed waste gate.
11,941
16,527
Kendal, Cumbria
since 1999
I almost feel left out :D
However I find your criticism of my reply just a tad patronising - something that in my experience the motor trade practice widely. Just to put the record straight my answer was borne of limited but valid experience of Diesel engines and of 50-odd years avoidance of every aspect of the motor-trade. (I have not, as yet, found the need, or any reason, to take any vehicle I have owned to a garage.)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Not even for an MOT? You have been lucky enough to afford a new car at less than 3 year intervals for 50 odd years, well done that man. :)
D.
bartiny
284
404
Since 2008
Still Waiting.
Ah well lets not let facts get in the way EH?
:whistle2:
bartiny
284
404
Since 2008
Sorry you felt patronized, the above highlighted in red is the bit I do not agree with, there is no "could" you have said that "mechanical failure occurs", not factually true for all stuck waste gates.
Thats all on that one(y)
toyota
Jun 1, 2009
77
98
coachbuilt
6 years
May i say thank you all very much for your replies, not being mechanically adept i have no idea where the turbo pipe is located.but thank you all for your time and inputs.i will see if anyone on the site here in spain camping villasol is able to point me the right way.
kind regards john
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I've no clue what the cause might be, but having had a turbo hose work loose at the jubilee clip twice on my 2.3 JTD it's always worth checking that the clip is fully tightened if you've got the bonnet up. Prior to the last time it popped my MH's performance had been flagging. After I fixed it back properly things improved greatly.
Aug 6, 2013
11,941
16,527
Kendal, Cumbria
since 1999
Sorry - I haven't kept up with this - you are of course correct when you say mechanical failure doesn't always occur.:)
