Powering our Microwave (1 Viewer)
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
We have a built-in combination Microwave / Oven in our van which is plugged into a standard 13amp socket.
Up to now we haven't had any problems because we've only been to sites with hook-ups but what should we do when we start going 'wild'?
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
:ROFLMAO: buy an inverter or don't use it :thumb:
You will need at least 1,000 watt inverter if you have a 700w micro because it surges to start,better not to use it wild :ROFLMAO:
terry
Pikey Pete
1,481
1,143
o
o
As said previously, learn to live without it. Using an inverter is a huge drain on the batteries.:Sad:
TweetiePie
116
67
Mid Wales
Movano self build
on and off since 1968
I used an inverter for an 800 watt microwave, it was a 1000 w and work OK with two 110amp batteries and a solar panel to top up the batteries. We used it while using french aires for 8 weeks but only for about 20 to 30 mins a day
moandick
1,312
112
Landrake, Cornwall
Euro-shed
Sorry, Digger, but some plonker like me was bound to ask - "!How do you cook a roast in a generator?"
oldun
747
162
St Neots
VW Campervan
Since 2001
A 110Ahr battery would at the very best supply 100A for 1 hr at 12V = 1.2kw for one hour.
In practice it would provide only about 60% of this, i.e. 720W for one hour.
To look at it another way a 1000W converter would (again in theory) take 1000/12 = 84A. In practice it would be nearer 90A.
This type of current means that the inverter must be wired directly into the battery using very stout cables.
In general large inverters are only feasible with large banks of batteries or are just for emergency use.
American Dream
156
Lincoln
I would use a generator!
Much less bother!
Genny for me too.:thumb:
An inverter with that sort of power output and proposed run time would flatten the Leisure batteries in no time as has been mentioned previously.
I guess if you're going "wild" then perhaps it IS best not to use it.
oldun
747
162
St Neots
VW Campervan
Since 2001
you could always spend a small fortune on a 12v microwave.:thumb:
This would also impose a huge drain on the batteries and the motorhome wiring loom.
For example 720 Watt is 60 amps - no standard motorhome wiring can get anywhere near 60 amps. Most circuits have a maximum of 25 amps or much less.
You need a very serious 12V power supply and non-240V charging system to provide such power.
For standard MHs microwaves are a no-no without 240V ehu.
Thepips
Trade Member
Sep 26, 2007
493
Basingstoke
RV
Our RV does have a 3kw inverter and 4 6v 125 amp hour batteries. The inverter/charger is mounted right next to the batteries with cables the size of starter cables. I have used the microwave off it, 5 minutes of microwave power doesn't hurt the batteries but I wouldn't want to cook a meal:ROFLMAO:
Regards
Doug
43,304
49,293
the one i was looking at was only 124w...:Eeek:
you'de forget what you were cooking before it was cooked..:ROFLMAO::ROFLMAO::ROFLMAO:
43,304
49,293
buy a generator.....no more worries :thumb::thumb:
11,842
14,067
Eastbourne East Sussex
Hymer low profile
Since 1972
I'd go with Pappajohn on this. A generator of a suitable output will probably cost you half as much as an inverter and some are quiet and resonably light. If you're not bothered about the noise you can get a cheap generator for £90 whereas a 1300w inverter will set you back £400-£500. The inverter isn't weightless either and if you need an extra battery or two will outweigh the generator.:RollEyes:
oldun
747
162
St Neots
VW Campervan
Since 2001
Good grief!
A genny or inverter plus 12V microwave - what a cost.
it's much cheaper to eat out at the Ritz.
Or failing that its even cheaper to stay on a site with an ehu.
