Power to TV (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Been away for a few days and was watching our new to us, Avtech telly when it suddenly displayed the message "Low voltage, switching off" and with that, it turned itself off. I had forgotten to switch the Sargent charging unit back on having turned it off overnight because of the fan noise. Switching it back on solved the problem.
The question: I was under the impression that the charging unit just charged the batteries (we have a leisure and vehicle battery.) I know all the fuses and trip switches are also housed in the unit but thought that this was just for convenience. We were on EHU at the time so assume we were using power from that source and not from the battery? Why does the Sargent unit have to be charging for the EHU to work? We were also using power for heating, fridge etc at the same time.
Your wisest thoughts would be much appreciated.
Jerry
43,319
49,401
Once battery voltage drops below the threshold set by avtex it will turn off to conserve battery power.
Turning off the charger meant you were solely running on battery power.
When on hookup with the charger on you will be using the charger output to run 12v....the battery is there to provide any power over and above your chargers max output.
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Thank you Pj. So the limitation only applies to 12v appliances if the charger is turned off? Not anything running on 240v?
