Power Supply
Discussion in 'Tech/Mech General' started by Wildge, Jan 17, 2015.
  1. Wildge
    Wildge Funster
    Jul 24, 2013
    1,364
    1,583
    Derbyshire
    :( Does anyone know of an alternative power supply when not on ehu. Needs to be available to run Medical equipment overnight so gennie not an option. Seem to think I have read somewhere on here about ? Power cells ????. Or have I got that completely wrong (n) Already have 80w solar and twin batteries .
    Please keep it simple guys :eek:
    thanks Jude
  2. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,434
    15,187
    under a wand'rin' star
    • Like it Like it x 2
  3. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Sun, Wind, Chemical, Gennie. Take your pick.
    The socially nice one is chemical, turning alcohol into electricity silently. See Efoy.
    • Like it Like it x 1
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,772
    8,014
  5. TheCaller
    TheCaller Funster
    Sep 23, 2013
    2,008
    2,361
    Lincs
    A fuel cell would be an expensive but silent & fairly reliable option.
    One or two members have them.
  6. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    264
    182
    Rushden, Northants, UK
    If it needs to be separate from the rest of the motorhome electrics then fit a third battery and charger.
    If you need more than a battery will provide, there aren't many options for night use.
    Peter
  7. Wildge
    Wildge Funster
    Jul 24, 2013
    1,364
    1,583
    Derbyshire
    (y) Thanks for all your input. Have just been looking up the actual energy required and the machine uses 700w .Not being at all technical could this run all night with a genny to recharge next day ??
  8. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    presumably you are thinking on running from a 12vdc - 230vac inverter.. ?
    700watt , dived by 12v to get the amps..
    700/12 = 58amps,
    this would kill an 80ah battery in less than an hour..
    to run all night, 8 hours x 58amps = 464ah .. so you would need a battery bank of almost 1000ah .. :Eeek:
    you need to think again.
    Without EHU, A 1kw petrol / LPG fueled generator, or an Efoy fuel cell is the only practical solution ..
  9. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    AND you have to take into account "medical", certainly a gennie will fail sometime with those hours, then what happens ?
  10. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    same as what happens at home during a power cut ... or on a site with EHU and it trips out ..
    to be safe you would require a UPS that could maintain the supply for say 1 hour with an alarm to alert the carer that the genny had stopped or the mains ehu had tripped..
  11. TheCaller
    TheCaller Funster
    Sep 23, 2013
    2,008
    2,361
    Lincs
    700 watts is a lot of power, even for mains powered equipment. There aren't that many pieces of equipment, other than heaters of some sort (kettles, hair dryers, toasters etc) that draw that sort of power continuously. I think that figure needs checking - it might be a maximum start up draw, or maybe the kit only runs intermittently.
    The largest Efoy fuel cell only produces 110w continuous output.
  12. Red Dragon
    Red Dragon Funster
    Apr 23, 2010
    657
    1,395
    Isle Of Man
    Hi we are heavy electric users and into Skiing and wilding so I bought an Efoy (140) I have a battery bank of (260amp/hr) 2 batteries and a 100watt solar so we can be totally independent if needs must.
    The Efoy monitors my battery bank and when it lowers to 12.3volts the Efoy kicks-in and recharges the battery bank at approx 5/6amps hr,so it would cope with your situation nicely and also it very silent.
    Hope that helps.(y)
  13. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    yes,, good point, perhaps the OP could check and or take a photo of the data plate
  14. Red Dragon
    Red Dragon Funster
    Apr 23, 2010
    657
    1,395
    Isle Of Man
    Sorry just re-read those figures you would need a significantly larger battery bank to get you through the night time.
  15. Wildge
    Wildge Funster
    Jul 24, 2013
    1,364
    1,583
    Derbyshire
    (y)Thanks for all the replies ............Have not got the equipment yet so can only go on what is published :whistle:
    Back to the drawing board ............................ or looks as though it will be EHU from now on :groan:
  16. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,382
    18,067
    YO11 2BD
    Woah....that's novel.
    I change alcohol into water and gas
    • Like it Like it x 3
  17. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    70 watts from Efoy, 700 watts out, that's not going to work, depending on how long the 700 watts is running.
  18. Daifuse
    Daifuse
    Feb 20, 2013
    184
    310
    Milford Haven
    My wife says I do the same - but I reckon it' the dog, PHEEWWW!
  19. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,030
    1,826
    Essex
    hmm. Depends.
    How critical is the medical equipment ? i.e - if it loses power, what impact would it have on the patient over what period of time ?
    The 700W you quote:
    Is that the "boiler plate" figure ?
    I assume it's 230V AC ?
    Who's medical equipment is it ? Yours or "on loan" ?
    Without knowing the above:
    I wouldn't recommend reliance on a generator - far too much that can go wrong, even down to silliness like running out of fuel.
    If you go down the generator option, then using an online UPS downstream of the generator will increase integrity. Although to maintain a 700W, you'll need a fairly hefty UPS (and battery/s) to maintain any kind of useful autonomy - I can do the calculations if you require.
