power supply meter (1 Viewer)
N
Nobody
when on hook up is there meter you can buy that when plugged into a socket it would show you the actual amperage you are consuming is there such a device:Smile:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Two ways.....
A 13A plug in unit that shows what current is flowing through it - difficult to use for the hook up lead.
A clamp on sensor which requires that you fit the little clamp/transmitter round the main live feed to the van. You need to work inside your consumer unit to get at the wire, or maybe the wall mounted plug where you plug your hook-up into.
All on the maplin web site.
zaskar
1,159
371
UK
5th Wheel
Yes. It's called an Owl Power Monitor. It's available from Argos for about £30 and is WELL worth it.
I bought one on the recomendation of ScotJimLand and even tho I'm very good at juggling/balancing power usage from experience, I've still found it to be an EXTREMELY usefull bit of kit to have.
It's wireless, easy to fit and extremely acurate.
scotjimland
2,318
9,996
A Woosh bang
As previous suggestions,
I bought an Owl about 18 months ago for the RV but now use it indoors.. great bit of kit.. :thumb:
I bought from Argos, but Tesco Direct have it cheaper
Link Removed
Not so long ago they had them 'in store' on offer .. worth checking
43,323
49,440
i use the owl monitor and it is good....
it doesnt show amps but does show Kilowatts
an easy conversion to amps though.
1kw = 4.34amps @ 230v....4.16amps @ 240v
divide kw by volts = amps
scotjimland
2,318
9,996
A Woosh bang
Correct John..
but you can set the alarm to go off when you reach say 16A
16A x 230V = 3.68 kw
I set mine to alarm at 3.6kw which allows for any errors .. also lets you switch off before it trips..
For lower amp supplies you must remember to reset the alarm, so a 10A ehu would be set at 2.3kw
43,323
49,440
Correct John..
very true Jim but as i havent used mine in the van yet i forgot about the alarm function. :Doh:
