Harry ullrich
Have just purchased an elderly Herald Insignia 400E 1997 it came with the manual but nothing on the above unit the top right hand rocker says heater (water or heating) and the row of fuses 10 amps what do they fuse?
leisure battery to power the fusebox, but with british vans the convention has stupidly been to fit a relay that cuts off power to the habitation area when the engine is running. If this relay or the feed to it is compromised you will get no power to lights pump etci will check out the board for it , which battery leisure or car pls driving me nuts this is
There a few specialist people out there that used to work for Plug-In Systems and another that is from ARC - he can service Carver control PCB's for instance so well worth adding to your address book (My MH is 1999 so you will probably encounter similar age related issues). PS if you have a Carver water heater then although they can still be repaired and serviced by specialists (MCEA engineers) take note that the Propex Malaga heater fits approximately the same space but is a 13 litre capacity rather than 9 litre and obviosuly uses more modern burner and controls.......Later PMS7 made out of aluminium. Has the external charger fitted into its rear.
The charger has a push and twist fuse holder in its top. If the charger stops working that is the first thing to check
Taken from - http://www.expluginsteve.co.uk/using-a-caravan-generator
