Power Issues (1 Viewer)
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Hello.
I have an auto trail scout 2005 and suffer from poor battery performance. I have 2x110AH batteries installed (less than a year old as initially replaced thinking they were the issue).
I have solar which saves the day as I get some charge back in the batteries when rough camping and the suns out.
Everything works ok or so it seems but I suffer with high drain when it's dark and I'm using lights. I've made sure everything else is off (Arial - reverse camera switch - etc) but something is draining the batteries. My lights have been replaced with LED strips thinking that would fix it but it hasn't.
Has anyone else suffered with similar issues or have any idea where to look for common drain issues.
Have done an overnight light test and battery drain is 3V over 12 hours. Is that excessive when just using LED strips. This does show 5.6A drain when all light on (taken from control panel reading) which I think is high but should that equate to 3V loss.
Any help appreciated.
funflair
19,305
30,071
Guisborough
MORELO palace
since 2012
When you say 3V drain do you mean 12.7v goes to 9.7v, that would be way too low.
A draw of 5.6 amps for a few hours should not make too much of a dent in your capacity.
Martin
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
If your voltage drops to 9.7V the batteries may well be beyond salvation.
43,304
49,291
A 5.6a drain will deplete your 220ah battery bank by around 25% over a 10 hour period.
That should equate to around 12.5v indicated voltage.
If your batteries are losing 3 full volts, 12.7 down to 9.7, then your solar panel will NEVER charge the batteries to full capacity
Your batteries are knackered regardless of being a year old.
Edit....just noticed you say control panel reading.
Ignore that reading, buy a multimeter and take voltage readings at the batteries..
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Thanks for he responses folks.
Funfair yes that's what I mean.
Funster I'm trying to confirm that as if they are then they're still under warrantee and will be returned for testing / replacement.
Pappajohn I agree it's just an indication but I have used a multimeter on the batteries themselves whilst disconnected and both batteries generally report the same voltage as the control panel reading shows so it's reasonably reliable it seems. Are you saying the loss of 25% should be expected as 25% of 12 is 3 which is what I got. Or do you mean 25% of 220AH as in 55AH which is what I'd expect at 5.6A X 12 hours approx.
I'm just trying to better understand the way my electrics work. Even at 9.7V the lights worked fine still. Just voltage levels showed low. 100w Solar gets them back to 13V usually after a sunny day unused sat on the drive but I'm planning on taking both batteries off and charging them externally to the van for a couple of days to see if that improves anything anyway. Appreciate you can't beat a proper battery charger to get a proper charge or so I've been told.
Q. Does the draw 5.6A sound excessive for LED strip lights. 6 X 0.5mtr strips.
Q. How does AH convert to Volts. I understand Amps / Hour etc and how that adds up but can't remember if I ever learned how that equates to what Voltage loss I should expect to see. V=IR is all I remember lol.
Thanks again.
Dave.
TheBig1
17,602
43,073
i suspect the solar panel or controller are faulty as when fully charging should read 13.8v
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
TheBig1. I Will check to see what it gets up when it's had a day charging.
I tested battery drain again last night without the solar connected to prove its not back draining the system as I am aware it does this when no sun shines according to the manual. The drain was similar to the test with solar re levels. Battery shows low. 9.7V this morning but lights were still working.
With solar connected it's now charging the batteries again but obviously shows low battery on it.
For info the solar is wired into the vans control unit (using the interface connector I bought from them for solar connection). This means it will charge both leisure batteries and cab battery. It's set at 70%/30% split in favour of leisure battery as I deemed that to require most charge when rough camping. It sees leisure batteries as one though (as the the van does) even though it built with 2 in it. This wil obviously effect it's charging ability as its giving 70% of what it can to both batteries.
Will keep you posted.
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
I post this without technical knowledge, but passing on my own experience
When we bought our MH used but very little use, the two fitted leisure batteries appeared to be useless, bought 2 new ones and fitted them (a friend did) then found that one of them was completely gone but the other was still perfect, but the bad one took them both down to unusable low levels. So maybe one of yours is weak
Also I was amazed at the amps drawn by the fluorescent starters, even with a failed tube, one light was still taking nearly 3A when switched on, have you changed any fluorescent lights but left the starters wired in?
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
The LED lights you describe will probably work way down to 6V. It is not possible to equate voltage drop to usage as this is entirely dependent on battery size and condition. When charged your batteries should be reading 13.8V, when in use rarely below 12.0V.
At 9.7, if your voltmeter is accurate, the batteries are done.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
DavidG58. The lights were removed as a unit. Wire only left and new LED strips replaced them completely unless I'm missing something hidden away.
I'm going to try and lid test each strip with an amp meter on the battery to see if it's an individual unit that's faulty it something like you mention spotted.
When I've checked the batteries direct (on their terminals while disconnected) they always show similar levels so I assume they are both in the same condition. Both were bought together and fitted at same time.
WillH. Will keep an eye on them and if deemed shot will return them to where I purchased them. Then can do a test on them and if they agree hopefully they will be replaced under warrantee.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Thanks again for all the replies and keep them coming. I'm learning loads from people's comments and hopefully someone will suggest something that is my actual fault. If not I'm eliminating things anyway.
Thanks again it's really appreciated.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Another thought I've had is my van has an alarms system with a PIR in the habitation area. I know these don't draw much but is the alarm itself sited somewhere as I can't find it and also is the power taken from the cab or the leisure batteries. I expect it's the cab as its part of the van alarm system I think.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Just check my LED strips, if yours are similar to mine the power draw you have is equivalent to 14 metres of LED strip so there is something else drawing power.
Dec 23, 2014
2,175
2,805
South Somerset
Carthago C-Line I 50
Since 2009
Have you changed the mini halogens in the wardrobe and the control unit locker for LED's?
denisejoe
5,616
12,042
Warden isle of sheppy
Since 2004
The 13v you see from the solar is the charge that is being put in not the state of charge of the batteries to do that you would have to wait a couple of hours after sunset
Joe
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Will H. Thanks for that info. It's probably because I have cr*p LED's then. I have 6 strips all less than a mtr. May look at replacing them for lower power ones. Thanks for that info.
Dorsey Diver. Yes I have. But they are only on infrequently. Anyway so doubt they would be the problem. Unless you know something I don't.
DeniseJoe. I wired the solar in with accessible inline fuses so I can easily disconnect batteries (leisure or cab and the solar panel itself if required). When taking measurements for my batteries I've been disconnecting them from the solar so that I know the reading I'm getting is charge free etc.
I'm thinking my strips may need replacing due to the large draw. That's for starters anyway.
Thanks again for the responses folks.
denisejoe
5,616
12,042
Since 2004
Dave, you still need to wait a couple of hours after disconnecting to check the charge.
Joe
Dec 23, 2014
2,175
2,805
South Somerset
Since 2009
I got caught out by three things.
I didn't change them.
My own stupidity in that as I kept the locker door open to see all the controls it did not occur to me that the light being on was adding to, or was, the problem :tmi:.
The light switch in the wardrobe was not correctly adjusted so the light was on all the time :tmi::tmi:.
scotjimland
2,256
9,780
A Woosh bang
classic... glad you found the problem..
it reminded me of an old car I had, the battery kept going flat overnight.. discovered the boot light was on permanently :doh:
always the simple things that catch us out
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Cheers Joe. Will give it a couple of hours before taking readings.
Scotjimland. Wasn't my problem that was fixed. Lol. I'm still looking but thinking of changing all LED strips. Got them off eBay so probably made by a 5yr old in a sweat shop somewhere so will look for something better.
Will keep you all posted if I find a solution / improvement.
Thanks. Again.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Just checked the manufacturer spec for my current strips. 14.4W per 1/2 mtr. Nice and bright. But that equates to 14.4/12 = 1.2A ish. Add up my strips and that's quite high. Hence the 5.7A draw when all in use. Changing lights and then will start again and see how I get on.
Jaws
23,832
72,343
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Strewth ! They must be the most power hungry LED strips in the world LOL !!!
My 5 metre strips both draw under well under 2 amps..
My .5 metre strips all draw about .125 amps ( so when all 14 are on they still draw less than 2 amps !
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
I've taken some readings. These are accurate readings taken with a Digital Volt Meter on Amps connected in-line on both batteries separately. Results are in the enclosure.
Think my display on the van reads a little high based on these. I've been told control units sometimes give readings based on a Voltage reading and applies an algorithm to convert to Amps which may explain them.
Please let me know what you think.
Thanks.
Dave.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Tonyidle please explain. Why would you say that. Both leisures produced similar results. Obviously the load was less when split over both batteries. I actually thought the readings looked good. What am I missing.
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
As a follow on to all you lovely people who commented on this post. I have got to the bottom of my issue. I returned batteries to dealer and they returned them to the manufacturer.
The manufacture have tested the batteries and confirmed there is nothing wrong with them. Apart from 1 little issue.
They were infact not leasure batteries but car batteries. They were 110 car. Breakdown in communication when shop ordered them in. To Be fair they looked like leisure batteries in size and shape and labels didn't say they weren't. Getting 2 replacement leasure from them so hopefully all will be good.
tonka
10,826
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
Only just seen this thread and glad things may look to be sorted.
A little note that may help people and something that I know caught a few Autotrail owners out..
The rear view camera have Infra red leds for night vision BUT if the camera is left powered on, so are the lights. This can give 24hrs constant drain. Not sure of what the IR take but it's something else to consider..
Dave Flegg
Mar 8, 2015
77
35
Leeds
Auto Trail Scout SE
Since 2015
Cheers Tonka. Yes I found that initially. Always make sure I turn the system off as it draws quite a lot especially with the screen powered up ready for reverse selection as well (as the system does).
