- Jul 1, 2010
- 3,198
- 33,419
- Hymer B 588 DL
- Since September 2010
Just back from a week away during which we noticed that gas pressure seems down when using say oven and gas rings, as each is lit jets on others diminish, also Truma fire which we usually set at 2.5 keeps re-igniting in breezy weather, oven seems most affected with very small flame with oven hobs lit?
We have a 2 x 11kg Alugas refillable system fitted with a Gaslow Auto Changeover valve, van is 11 months old and fitted with a Truma MonoControl CS regulator.
I'm wondering if the regulator is starting to fail, there is however an odd thing happening with the Gaslow auto changeover indicator in that with one gas cylinder isolated red area is visible indicative of low pressure. If I open up both cylinders red indicator area is more visible. Both gas cylinders are full!
Very perplexing, I've attached 2 photo's 1st shows the indicator with only 1 cylinder opened and valve selection in manual (for that cylinder) second is both cylinders open and valve selector in auto.
I'd appreciate your thoughts or advice.
