Possible clutch judder on 59 plate transit based motorhome
Discussion in 'Motorhome Chat' started by kelpbeds, Sep 28, 2011.
  1. kelpbeds
    kelpbeds Read Only Funster
    Sep 16, 2011
    101
    13
    shrewsbury
    Hi,
    I just bought a 59 plate Chausson based on a 2.2 transit.
    When I pull away in 1st gear there is a little judder on the clutch and you can stall it if you are not careful.
    However, with a bit of getting used to it and careful clutch control there is no judder at all, just need to give it a bit more right foot really.
    Now I don't know whether it's just me that needs to get used to it or if there's a problem. Anyone else either got a transit and can tell me what there's is like or knows anything about this?
  2. Popeye
    Popeye Funster
    Sep 5, 2011
    7,804
    17,360
    New Forest
    Sounds like you have a problem with the dual mass flywheel. Shouldn't be a problem on a 59 plate though, just take it along to your Ford Dealer and have it replaced under warranty.
    Best of luck:Wink:
  3. kelpbeds
    Sep 16, 2011
    101
    13
    shrewsbury
    Thanks for the reply, might well be the wise thing to do.
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,272
    10,766
    E Yorks
    This is a typical Ford trait, we've had it, and have experienced it on other Fords, both Mk 6 and Mk 7 - trying to pull away can be a pain until you get used to it as you'll often stall it. I wouldn't think it is a fault as such, it just means that you have to have to learn the 'method' of Ford clutch control ....:RollEyes:
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    have you had a transit base before ?
    my previous experience with various transits (not motorhomes) is, they need a little more 'urge' on the loud pedal before letting the clutch in from standstill.
    but then I'm biased.....never have liked Ford diesels, the older ones sounding like shaking a cast iron bath full of hammer heads :RollEyes:
  6. kelpbeds
    Sep 16, 2011
    101
    13
    shrewsbury
    Thanks for replies no I haven't had a transit base before which is why I was wondering if it was me or not.
    Any other opinions welcome, cheers.
  7. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    I can also agree it just sounds like a Ford transit clutch. I have always found that a little bit more loud pedal on starting off was required
  8. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    "They all do that Sir"
    No they don't......
    I have an 05 Transit base vehicle, and it's silky smooth pulling away.
    I think you'll just have to adjust to its foibles.....
  9. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    359
    164
    Norfolk
    Hi, if you are talking about the automatic rise in revs as you pull away in first gear, don't worry this is Fords answer to help you not stall. A little rev blip was introduced in the latest software remap, you soon get used to it, :thumb:
    Regards Richard
  10. dogmanlpool
    dogmanlpool Read Only Funster
    Jun 9, 2009
    98
    38
    liverpool
    hello there i wouldnt worry about it most vans when left parked up do the this my merc has been doing it and my swift done it before that so bit more gas and when the clutch plate warms up it will be fine ?
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    We have a Chausson on a 2010 RWD Transit 2.4 140ps, it needs a few more revs than you'd expect to get it moving without an embarrassing stall, but take-up is always smooth.
    My 2007 2.2 85ps FWD work van, however, is much more diesel-like and pulls away with far fewer revs on despite the fact it is near its max gross weight of 3000kg all the time. I have known this van to judder very occasionally if I pile on too many revs and slip the clutch in a effort to keep the turbo spooled up and pull away quickly. It has covered 105k on its original clutch and flywheel so far, however........
    So say clutch judder is a Transit trait I feel could be misleading.
    If you are genuinely getting juddering, I'd run it down your local Ford dealer just to be sure it gets sorted before you have to pay yourself!:Sad:
  12. kelpbeds
    Sep 16, 2011
    101
    13
    shrewsbury
    Thanks again folks, it's not major judder and isn't there at all with a bit more revs so just sounds like a ford thing, but will get it checked out just in case.
