Position of Fiat Ducato battery
Discussion in 'Motorhome Chat' started by beachcaster, Nov 16, 2011.
  1. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I gather the battery is under the drivers seat .....and that you have to remove the drivers seat to get at it . I started to look for it under the bonnet..silly me.
    Just getting to understand my vehicle in greater detail...but that must be a pain for jumpstarting etc.
    Any useful tips for getting access ?
    barry
  2. Gromett
    Gromett Funster
    Feb 27, 2011
    8,103
    14,727
    UK
    Fiat ducato batteries are normally under the bonnet at least in all the ones I have had. Top left as you look under the bonnet.
    Unless you mean the habitation battery?:Blush:
    • Like Like x 1
  3. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    They are a pain to get to, and even more of a pain to replace as it is tight under there. For jump starting, just be careful and hook it on as secure as you can.
    If you ever need to replace the battery, then do remove the power steering res before you attempt to pull it out as it will make you life alot easier!
  4. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    No habitation is in a locker round the side
    No sign of the battery under the bonnet...........2009 autotrail
    barry
  5. kinsleyboy
    kinsleyboy Read Only Funster
    Dec 11, 2009
    115
    15
    Shropshire
    In my X250 Ducato based Bessacarr, the vehicle battery is under the floor in front of the passenger seat.
    The habitation battery is under the floor below the nearside sideways facing seat in the living area.:Smile:
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,344
    7,468
    Nr Watton in Norfolk
    For jump starting there should be a remote +ve terminal under the bonnet for just that purpose & the -ve you can connect to any suitable chassis or engine bolt so long as it is well grounded.
    • Like Like x 2
  7. rangitira
    rangitira Funster
    Jun 30, 2010
    6,377
    13,167
    Cornwall
    You're never to old to learn:Blush: Thanks for that piece of info:thumb:
    • Like Like x 1
  8. icantremember
    Sep 2, 2010
    5,344
    7,468
    It's not the learning t'is the problem .............it's remembering what I've learnt.
    Now....what the hell was I talking about:Doh:
    • Like Like x 3
  9. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,235
    883
    St.Helens
    dependent on the model, try between the front seats, towards the rear near where the main cab as supplied from the factory finishes and the home unit starts - in the main cab bit.
  10. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Thats sounds good.............can you tell me what Im looking for and what is a Ve terminal ?.............. this would make sense....if only I knew what I was looking for.
    barry
  11. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    under the bonnet at the right hand side there is a box with a small flap on the rear of it which has a + in a circle on the top.
    when open it looks like a wrigley piece of tin this is the +
    just under the bonnet also at the right hand side right at the front there is a brass coloured bolt just sticking up this has an earth symbol on it. and thats the -
    hope this helps
    • Like Like x 1
  12. icantremember
    Sep 2, 2010
    5,344
    7,468
    Sorry Barry, +ve is the positive connection which is probably near or attached to the fuse box under the bonnet & on mine (2010 Boxer) is a bare threaded bolt within a protected area.
    Mine also has manufacturers stickers indicating it,s position and use.
    The negative connection from your charger goes on to the chassis anywhere to get a good ground.
  13. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Thanks for all the feedback on this thread....its been really useful.
    A couple more questions.......I just looked and found the little box with a +
    on the top ........but cant see a specific - connection....yet for the negative
    When you say the negative lead goes to the chassis.........is this ok as the chassis is galvanised.......not bare metal.
    But this is all good stuff and looks like I may be ok for jumpstarting with my heavy duty leads without lifting the floor up inside the van to expose the battery.
    Now for what might be a daft question.....Can I use the same setup for charging the vehicle battery........???? With a battery charger of course.
    ( thats a theoretical question now as it seems I can direct the onboard charger to either the habitation battery....or the vehicle battery on my control panel.)
    barry
  14. icantremember
    Sep 2, 2010
    5,344
    7,468
    Hi Barry,
    I would not connect negative to any galvanised part of the chasis but to any unpainted or nongalvanised bolt or metal bracket around the engine bay.
    I can't get to my van at the moment to give any particular detail but my Volvo car has the same setup as the battery is in the boot area and I connect the negative for jump start or charging to a bracket bolted to the cylinder head which is a lifting point for engine removal.
    Brian
