Portable Epson Printer (1 Viewer)
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Bailey Approach 740 SE
bought one of these to use via iPad and AirPrint in the motorhome
My question is ......... Will it " marry " to a CC WiFi network on site to facilitate printing ?
Cheers !
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
If it's a true AirPrint printer then you should be able to set up an Ad-Hoc network between your iPad and Printer to allow printing.
What's the model number of the printer?
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
It's a WF-100
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
Ok, I think there are two ways you can try.
One option is to buy a cheaper wifi router and set up a simple network, connect the ipad and printer to this network and print using Apple's AirPrint feature or Epson's iPrint app.
The second option is to run the printer in Simple AP Mode, it looks like a setting under Network Settings/WiFi Setup/WiFi Setup Wizard.
DBK
18,004
47,947
Plympton, Devon
PVC, Murvi Morocco
I believe there is an Epson app you can get, called iPrint. This should allow you to link directly to the printer.
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Would I need a wifi connection , want I want to do is print stuff out using CC or pub or campsite wifi ?
1,588
2,281
Lancaster
None
Since June 2008
Would I need a wifi connection , want I want to do is print stuff out using CC or pub or campsite wifi or ?
In order to use the campsite wifi both your printer and iPad would need to be connected to the same wifi and you'd need the allocated IP address of the printer which would change every time you connected.
It really would be simpler to buy a cheap router and set up your own network or use the AP method I mentioned earlier.
DBK
18,004
47,947
Plympton, Devon
PVC, Murvi Morocco
Does the app and the printer communicate without wifi tho ?
It might, setting up a local link, can't see why it shouldn't - but the app is free so I can only suggest giving it a go.
It does work on a WiFi network as they connect via the internet - the printer could be at home and you on a CC site!
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Talk to me about the AP method , I'm lost !
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Thank you very much , I'll give that a go first thing tmoz , mighty impressed , great forum comes good !
old1
51
73
Bluetooth printers are the way forward, no wifi needed, a little dearer but well worth it.
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
671
169
Leicestershire
Beginners, got Doggy the van - March 2014
Can someone recommend a good/inexpensive/light weight printer to work wireless with IPad?
DanielFord
3,020
3,086
In which case, I'd refer you to the above posts, this Epson got a recommend from a user. Not used it myself, so couldn't say. I only have a photo printer in the van.
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
The Epson , according to the website , prints photos as well as documents.
DanielFord
3,020
3,086
Indeed, however, a dedicated photo printer will probably use the thermal print system, and give a better quality print. An inkjet will print onto photo paper, which gives pretty good results to be fair. If you want both, then a portable inkjet like the Epson sounds ideal.
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
The only downside is that the unit ain't that cheap ( I gave myself a cheeky treat ! ) and printing pages is about 6p for black and 15p for colour .
Can't wait to use it in anger in the MH ! I love gadgets me !
