Portable Epson Printer
Discussion in 'Motorhome Chat' started by Adbt, May 26, 2015.
  1. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    bought one of these to use via iPad and AirPrint in the motorhome
    My question is ......... Will it " marry " to a CC WiFi network on site to facilitate printing ?
    Cheers !
  2. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,373
    1,446
    Lancaster
    If it's a true AirPrint printer then you should be able to set up an Ad-Hoc network between your iPad and Printer to allow printing.
    What's the model number of the printer?
  3. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    It's a WF-100
  4. Linda and Steph
    Jun 18, 2008
    1,373
    1,446
    Lancaster
    Ok, I think there are two ways you can try.
    One option is to buy a cheaper wifi router and set up a simple network, connect the ipad and printer to this network and print using Apple's AirPrint feature or Epson's iPrint app.
    The second option is to run the printer in Simple AP Mode, it looks like a setting under Network Settings/WiFi Setup/WiFi Setup Wizard.
  5. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,066
    12,416
    Plympton, Devon
    I believe there is an Epson app you can get, called iPrint. This should allow you to link directly to the printer.
  6. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    Would I need a wifi connection , want I want to do is print stuff out using CC or pub or campsite wifi ?
  7. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    Does the app and the printer communicate without wifi tho ?
  8. Linda and Steph
    Jun 18, 2008
    1,373
    1,446
    Lancaster
    In order to use the campsite wifi both your printer and iPad would need to be connected to the same wifi and you'd need the allocated IP address of the printer which would change every time you connected.
    It really would be simpler to buy a cheap router and set up your own network or use the AP method I mentioned earlier.
  9. John Laidler
    Jan 9, 2013
    9,066
    12,416
    Plympton, Devon
    It might, setting up a local link, can't see why it shouldn't - but the app is free so I can only suggest giving it a go.
    It does work on a WiFi network as they connect via the internet - the printer could be at home and you on a CC site!
  10. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    Talk to me about the AP method , I'm lost !
  11. Linda and Steph
    Jun 18, 2008
    1,373
    1,446
    Lancaster
  12. Linda and Steph
    Jun 18, 2008
    1,373
    1,446
    Lancaster
  13. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    Thank you very much , I'll give that a go first thing tmoz , mighty impressed , great forum comes good !
  14. GRC
    GRC Funster
    Jul 28, 2012
    107
    166
    Northampton
    Bluetooth printers are the way forward, no wifi needed, a little dearer but well worth it.
  15. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    • Like it Like it x 1
  16. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Can someone recommend a good/inexpensive/light weight printer to work wireless with IPad?
  17. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,593
    2,785
    Surrey
    To print photos, or documents?
  18. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Documents, thanks Daniel
  19. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,593
    2,785
    Surrey
    In which case, I'd refer you to the above posts, this Epson got a recommend from a user. Not used it myself, so couldn't say. I only have a photo printer in the van.
  20. Adbt
    Adbt Funster
    May 19, 2015
    623
    926
    Cheshire
    The Epson , according to the website , prints photos as well as documents.
