Portable air con unit (1 Viewer)
errpaul
538
83
Wiltshire
11 yrs
Is it possible to get a portable air con unit that is small enough to use in the van, with a low enough power requirement to use on ehu, but that is actually any good and not just an expensive fan that sounds like a generator!??
scotjimland
2,256
9,780
A Woosh bang
short answer is yes, probably ... but impractical for following reasons
* Floor space.. where will it sit.
* Exhaust vent requires a hole in the van.. could use an open window but would defeat the object.
* Domestic units have high start up current, would need to be on a 16A EHU, many sites abroad ( where it would be most useful) only have 6 or 10A supplies.
* Storage while traveling .. would require fixing securely or put in garage/locker
If you really really need air con I would advise to save up for a roof or under bench Dometic unit .. but they are around £1k + fitting.
errpaul
errpaul
538
83
Wiltshire
11 yrs
Thank you
:Eeek:Thats a lota lota money:Eeek:
I had been told about ones that have a type of condenser so they don't need an exhaust??
I don't really know anything about them and have only seen the big domestic ones, which are far too big, about the size of a small tumble dryer!
