Poor water pressure (1 Viewer)
mof70
5
Cambridge
Hymer
Hi all
I have poor pressure, not personally but the pump in the van seems to work fine when I take it out and try it but, when I put it back and turn the tap on and we only get a dribble, does not appear to be air in the system as there is no spitting, any ideas before I buy a new pump.
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
Have you got a screw on bubble filter thingy (technical term)? Sometimes they have hairline cracks. New filter under £10. Just the thoughts of "sheer stupidity" blonde. :ROFLMAO:
scotjimland
2,324
10,060
A Woosh bang
Hi all
Submersible pump , yes ?
just a thought.. is your hot water boiler full .. ?
if it was drained down they take a bit of filling.. give it more time.
Have you tried opening each tap one at a time and running until no air bubbles.
Start with the tap closest to the pump.. not forgetting the shower.. do both hot and cold.
other than that, I'd get e new pump .. even if it proves not to be the pump, a spare never goes amiss.
D
Deleted member 29692
If it seems to work OK when you take it out then check the voltage at the connections when it is in place.
If something is dropping the voltage i.e. a poor -ve connection that could potentially cause the pump not to run at full speed which would explain the poor pressure.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Any water comiung out under the van? If so, the Truma pressure relief valve may have failed.
Otherwise, the pump motor may be running OK but the pump chamber(s) may have had it. A new pump is not that expensive (£38) and it's worth carrying a spare anyway.
Link Removed
M
mof70
5
Cambridge
Hymer
Hi all thank you for the responses it sound like a new pump, at least then I will know my current pump if work properly, I have not got any Air in the system and nothing coming out under the van,
Regards
John
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Regards
John
If you have that type of pump, they can go half wrong as they have two motors but will still run on one at half pressure
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Good point. Last time we were out in the Hymer, the kitchen sink hot would only work at a slow dribble, but everything else was fine. Took a while to trace it, but it turned out to be the hot tap switch connector under the sink. A spade male to female, properly sheathed, but a bad connection. Just a spot of WD, and removing then re-fitting sorted it. :thumb:
