Poor Service
Discussion in 'Motorhome Chat' started by Sweet Chariot, Apr 9, 2016.
  1. Sweet Chariot
    Sweet Chariot Read Only Funster
    Sep 30, 2007
    585
    6
    Staffordshire Moorlands
    My van has just been in to my local Garage for it's MOT and intermediate service. Considering at it's last service I had cause to complain as on collecting it one of the Electric Mirrors switch was not now working correctly following part of the work being to repair the Electric window mechanism and I found a scratch on the side of the vehicle. Following discussion both problems were finally put right even though on first taking the vehicle back the Mechanics attitude was, well how often do you use the wing mirror control does it matter.?
    On this occasion on collection the van I am told the rear Marker lights of which there are four, two were not working but as the other two did this was ok for the MOT. They then went onto inform me that they had not repaired the two because the screws holding the light on were corroded and it may cause problems to remove them. No problem I said I have bought new screws as i was aware the originals were corroded I would see to that myself. Oh and we also had to adjust your headlights they were also out of sequence for the MOT.
    In a hurry paid my bill and left, noticed first of all on driving home i was almost bouncing down the road. Checked the paper work, tyre pressures all set to 71 should be 55. cost to align lights and labour £39.50. Climb up to rear marked lights first one head sheared off holding screw second one completely mangled. Rang Garage where i was simply told the Mechanic had informed them he could not do the Marker lights as the head of a screw was sheared off ( Not what I was told) over the cost of the headlight work ring back Monday when the member of staff will be back at work. Anyway following paying a total bill of £280 have spent 4 hours drilling out the offending screws and designing a new fitting. What you call a bad day at the office. Oh and to add to that found a front sidelight out ( Fuse blown)
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    While you are there info them that additional high level marker lamps are NOT an MOT item.
    Only official road lighting. ie: the stop/tail/indicator/fog light cluster, should be tested
    • Like it Like it x 2
  3. scotzsue
    scotzsue Funster
    Apr 11, 2015
    961
    917
    hull
    Wondering why you used this garage again after your problems last time, but realise it might be the only nearby one which will MOT a motorhome.
  4. sedge
    sedge Funster
    Jul 7, 2009
    4,604
    4,143
    Nr Jct 3 M6
    I'd be willing to drive miles to avoid that one, anyway!
  5. wiljoy
    wiljoy Funster
    May 23, 2008
    900
    988
    Crook, Durham
    This garage must love you as you keep going back for more. Please change your garage before they wreck your van.
  6. Lee27
    Lee27 Funster
    Aug 23, 2015
    33
    18
    Lancs
    they could have "spent 4 hours drilling out the offending screws and designing a new fitting" and charged an extra £50+ per hour (£200.00+) on top, i suppose.
    • Like it Like it x 1
  7. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    I'm with Sue and Jenny, why go back there? (n)
    To stop this I always check lights and levels before mot time, less for them to fail it on.
  8. Sweet Chariot
    Sep 30, 2007
    585
    6
    Thanks for the replies had been using this Garage for 7 years no problems until the last 2 and yes next Garage who deal with Motorhomes some distance away. I was almost sure the Marker lights were not part of the MOT and as this seems to be correct why were they working on them anyway. I wondered if anybody has any experience of the cost of having lights levelled as this seems rather expensive as to get at mine remove 4 screws.
  9. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Well I do wonder why this cropped up as most vehicles have a levelling dial in the cab. It's really to lower the beam if you have a lot of weight on the back or are towing something.
    From start to finish of your post I think you were ripped off. :(
  10. Adbt
    Adbt Funster
    May 19, 2015
    592
    897
    Cheshire
    I really do feel your pain as there is nothing worse in the automotive sense than a trusted garage going down the pan .
    Get your snags sorted out and then move on , find another garage , in my experience once shot these places never get their shit back together .
    Good luck !
    • Like it Like it x 3
  11. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,731
    3,379
    Cumbria
    Got two new rear shock absorbers fitted to the Volvo last month, noticed it was starting to clunk again on speed bumps, just had a quick look underneath and they've both pissed out all their oil. Back to the garage tomorrow and I know there'll be no hassle, but I will question his choice of supplier.
