poor radio reception
Discussion in 'Motorhome Chat' started by Toe toe, Feb 20, 2015.
  1. Toe toe
    Toe toe Read Only Funster
    Aug 10, 2013
    38
    16
    Manchester
    I am struggling to get any good radio reception in motorhome I've tried fitting an booster arial but no better .Has any one fitted a dab radio and glass mouted arial and if so is the reception any better
    Thanks in advance
  2. maison
    maison Funster
    Oct 7, 2013
    1,690
    4,195
    South Wales & Burgundy
    Are you referring to the cab built in radio or one you carry in the habitation place?
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,779
    11,988
    Plympton, Devon
    Digital radio (DAB) is well known for poor reception. You may need an aerial which hangs outside, although I guess different radios exhibit better or worse reception. Also, of course, where you are is a big influence. DAB transmissions are more line of sight as I understand it.
    In our house the digital radio only works in a few spots, with an aerial sticking out of the window and when I am standing on one leg wearing wet, green socks. Or so I have discovered. The police believe that story anyway.
    • Like Like x 2
  4. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,431
    2,676
    Surrey
    I'm guessing the cab radio?
    Our reception was shocking, but I have a CB fitted, so I bought a splitter thingy, so that the radio can also use the CB antenna. We now get brilliant radio reception.
    I do realise that this reply probably doesn't help at all :rolleyes:
  5. maison
    maison Funster
    Oct 7, 2013
    1,690
    4,195
    If it is the cab radio what chassis are you running on.
    Our Fiat based M/H had poor reception. We found that the aerial is within the mirror housing and switched it for an externally mounted, extending aerial like cars used to have.
    Reception is much improved but still lose reception in some weak signal areas.
  6. Toe toe
    Aug 10, 2013
    38
    16
    Manchester
    Yes cab radio
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,833
    13,587
    Bolsover, Derbyshire
    Our radio is either brilliant or totally useless, still on FM, in A class with side glass mounted aerial
    I think as many have bad reception as good
  8. Brendan
    Brendan Funster Life Member
    Nov 25, 2012
    130
    243
    Scotland
    I had a similar issue with very poor radio reception, so last week I fitted a DAB radio and glass mounted antenna. It's early days yet, but so far I'm very pleased with the result.
    I positioned the antenna low on the window to avoid any issues with the overcab.
  9. westy77
    westy77 Funster
    Feb 17, 2014
    234
    178
    Essex
    We have a none dab aftermarket stereo and an aerial that is a black plastic bar looking thing at the top of the windscreen, I'm not sure how this works and is imo blocked by the over hang of the over cab bed area. I struggle yo get any signal at all to the point of not bothering with radio. I do want a solution though.
  10. Toe toe
    Aug 10, 2013
    38
    16
    Manchester
    Ours is fiat and fitted through mirror as well I tried a blaupunkt booster that is fitted to front windscreen but no differance .i am thinking of buying a radio that I can use iPod/usb as the best solution . Going to halfords to have a look.
    • Like Like x 1
  11. musson
    musson Funster
    Dec 25, 2013
    403
    141
    grantham
    I have tried two different radios and made no difference I was going to fit external aerial but ended up just
    laying the aerial at the bottom of the windscreen still not spot on but does work a lot better,Think my next
    thing will be a app radio and stream music from phone.
  12. StefAndDi
    StefAndDi
    Nov 3, 2014
    414
    941
    Near St. Austell, Cornwall
    Radio reception in our two Fiat-based Bessacarrs was dreadful. The base vehicle has a cab roof mounted aerial which is chopped off when the habitation element is added. So, as stated, the aerial is routed into the near side door mirror.
    We only have the radio on when travelling to keep up with travel reports, so it was important to us to resolve the problem. We started by having an external aerial fitted to the windscreen pillar; there was a slight improvement but reception was far from satisfactory. We were then advised to have the radio aerial routed through the Status aerial. Little improvement.
    So we have finally given up. Hoping for better with a different vehicle built as an A class.
  13. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    I found that the aerial plug was half out of it's socket when I investigated our bad reception, great afterwards.
    Some MHs have been delivered with the aerial just cut off by the converter. So have you a door pillar mounted aerial ?
  14. Yorick
    Yorick Funster
    Oct 1, 2013
    4,024
    5,950
    Lanzarote
    I have a DAB radio in cab and I get superb reception. Bought it from Halfords and came with a magnetic aerial that I've mounted on the roof :)
    I've tried aerials that stick on to windscreen but not very good.
  15. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,741
    8,830
    NW England
    Our (Fiat) cab radio reception was rubbish as it had no obvious aerial so we had a short external bendy aerial fitted on the passenger's side - it's fine now.
  16. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,775
    11,856
    Kettering
    FM reception in ours was terrible. Swapped the radio for a DAB one with windscreen mounted antenna and it's much much better.
  17. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,099
    6,090
    West Sussex
    Just have the passive stick on the screen aerial that came with our Clarion, get brilliant DAB reception never used the radio on FM.
  18. FJmike
    FJmike Funster
    Jul 17, 2014
    786
    850
    Swindon
    I had trouble with my aerial on my A class, really poor reception, so I tried one of the stick on ones like this Before sticking it on the windscreen I tried it with the aerial just lying on the dash and it was brilliant, receiving a strong signal where I hadn't been able to get a peep before. At six quid its well worth a try
    • Like Like x 1
  19. wingman
    wingman Funster
    Feb 10, 2013
    1,010
    2,548
    Romford, Essex
    Hi @Toe toe
    "Poor reception" is at least some reception, so it's almost certainly the aerial or its cable or connector. As a previous post stated, it's not uncommon for some vehicle builders to cut the aerial off cable during the build!
    If you have an antenna fault, a booster will only amplify noise! An amplifier will only boost what goes into it.
    You could try removing the radio enough to check the aerial connection at the rear. If connector plug is ok but reception is still poor, whilst it's out, beg/borrow/ or buy a really cheap car aerial and plug that in. If your radio blasts into life, then you'll know for certain it's the aerial. All you have to do then is decide what new aerial fixings or alternatives you have as a retro-fit.
    Whilst begging, borrowing, see if anyone has an old car radio. Loose-lay it in the cab, link it all up and see how it performs. You could also try a battery portable radio and see how that performs in different cab positions.
    My money however is on a damaged, cut or corroded aerial cable. Door mirror aerials are often suspect. Radio units themselves are normally pretty reliable. No point in spending fortunes until you sort the underlying problem.
    Please let us know how you get on
    Reg's
    James
    • Like Like x 1
