Pool of water under the toilet cassette. Thetford.
Discussion in 'Motorhome Chat' started by Dai Motorhome, Apr 21, 2014.
  1. Dai Motorhome
    Dai Motorhome Read Only Funster
    Nov 27, 2012
    151
    19
    Burnham on Sea, Somerset
    When I was emptying the toilet cassette I noticed a pool of what seems to be clean water in the recess where the cassette is fitted. I can't see any obvious source of the water. Anyone have any similar experience?
    Dai
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Possible drain off from rinsing the cassette after use, or even a poor seal to trap. Check other pipewoork for leaks when flushing takes place.
    • Like Like x 1
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,801
    If the seal has become hard, remove it and wash it in warm water to soften it a bit. When you put it back lubricate it with a little olive oil. If it is too far gone replacements are readily available.
    • Like Like x 1
  4. Dai Motorhome
    Nov 27, 2012
    151
    19
    How do I remove the seal?:Smile:
  5. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    i had a similar thing last year and it turned out to be a one way valve that is fitted on the flush supply up inside the actual toilet unit . it is plastic and had cracked during the winter lay up, the fresh water then found its way down into the cassette locker. the part was around £15 but it was a sod to get at in situ lots of cursing and swearing sorted in the end though !!! garry
  6. GJH
    Aug 20, 2007
    27,327
    34,801
    You first need to remove the capping piece(s) which are screwed onto the cassette. That varies a little between models but will be covered in the Thetford manual. If you don't have a manual they are available as PDF downloads from Here.
    • Like Like x 1
  7. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    There is a tutorial here
    [ame="https://www.youtube.com/watch?v=qlPkkieGvbk"]https://www.youtube.com/watch?v=qlPkkieGvbk[/ame]
    • Like Like x 1
