Polarity Query
Discussion in 'Tech/Mech General' started by Figaro, Jul 11, 2015.
  1. Figaro
    Figaro Funster
    Feb 22, 2011
    1,143
    887
    Newcastle under Lyme Staffordshire
    I wanted to do a small wiring job in my Hymer (2003) 544.
    There is a locker obviously intended for a 14" crt TV no longer used for housing a TV.
    I wanted to replace the 12 volt socket for a twin USB socket for charging phones / tablets etc.
    There are two wires brown and blue, when I put the multi meter on them : -
    Red probe to brown wire and black probe to blue wire the needle went down :(
    When I put red probe to blue wire and black probe to brown wire it registered 12 v.
    I had expected the brown to be live and blue neutral o_O
    Is this telling me blue is live and brown neutral and is this as it should be ? Or maybe I`m missing something.
    TIA
    Chris
  2. scotjimland
    Jul 25, 2007
    29,041
    25,733
    Suffolk
    Yes , it can be confusing , Hymer use brown as neutral - and blue as positive. +
    I discovered this when I changed the water pump.. I connected it the 'conventional ' way and it wasn't pumping properly.. then checked and found it was wrong polarity..
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,408
    9,455
    south shields
    yes that's what its saying... the blue is positive.. you are using an analogue type meter if it were a digital you would just get a -12v and + 12v to indicate the polarity.
    ta andy
  4. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Believe your meter, the Germans use strange colours. I damaged a TV knowing full well the colours were wrong but brain went on autopilot and wired up the TV reversed.
    • Like it Like it x 1
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,236
    15,222
    Leeds the one up North
    That's why we won the war :LOL:
  6. DBK
    DBK Funster
    Jan 9, 2013
    9,200
    12,786
    Plympton, Devon
    At the risk of muddying the waters, the terms Live and Neutral apply to domestic AC mains supply. For DC supplies the two wires are positive and negative and this is quite different to live and neutral.
    • Like it Like it x 2
  7. Techno
    Jul 28, 2010
    14,236
    15,222
    Absolutely correct and I usually pick that up but I'm on holiday still :p
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,054
    YO11 2BD
    NEVER rely on logic where motorhome wiring is concerned.
    I just fitted a volt meter and dual usb socket in my caravan.
    Voltmeter wiring is blue with white stripe = pos 12v....yellow with white stripe is neg 12v
    Usb wiring is plain blue =pos 12v....brown with white stripe = neg 12v.
    On my RV all major wiring is black.....with grey tracer numbers so small you need the Hubble telescope to see them.
  9. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,758
    8,006
    Should try an Autotrail.. From memory I think their negative is orange and white !!
  10. Techno
    Jul 28, 2010
    14,236
    15,222
    Pre swift Autocruise too but positive I think?. Not really a problem where the colour is nothing to compare with accepted standards but clearly a BLUE positive and a BROWN negative is designed to confuse the enemy if captured :LOL:
    Top marks to the OP Chris for using a meter!
  11. Figaro
    Figaro Funster
    Feb 22, 2011
    1,143
    887
    Thanks guys, excellent replies as usual (y)
