plumbing fault
Discussion in 'Tech/Mech General' started by breeks, Feb 18, 2011.
  1. breeks
    breeks Read Only Funster
    Jun 15, 2010
    135
    24
    glasgow
    hi i have an outside shower that is going on when i turn the wash basin taps on so i blocked it of from the outside to save water waste is this something to do with a valve anyone know its a hymer 534 1995. trauma heating system help would be appreciated
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    obvious answer seems to be turn outside shower off, but assume there is more to it than that.
  3. breeks
    Jun 15, 2010
    135
    24
    glasgow
    shower
    i wish it was as easy as that:Smile:as soon as i yous other sink taps water pours from outside shower
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    has it always done it or has it just started ?
    do your taps have micro switch's or is it a regular pressurised water supply ?
    i suspect micro switched and the outside tap is cracked internally...probably frost damage this winter.
    the shower tap is turned off so the micro switch is also off but the tap leaks.
    open another tap, the pump starts and water will flow from the damaged outside shower tap.
    solution....if you dont use the outdoor shower simply buy a couple of push fit end stops and blank off the supply pipes.
    if you do use it you need a new tap assembly.
  5. breeks
    Jun 15, 2010
    135
    24
    glasgow
    thanks for the info john:thumb:
