Plug sockets
Discussion in 'Motorhome Chat' started by paulweller84, Oct 28, 2013.
  1. paulweller84
    paulweller84 Read Only Funster
    Oct 24, 2013
    19
    Southampton
    Pretty simple question for those in the know I'm sure, do the 3 pin household sockets in motorhomes work off the leisure battery or only on hook up? If not, do I need a 12v tv to use it away from sites?
  2. estcres
    estcres Read Only Funster
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
    As far as I am aware the 230v sockets only work on Hook Up.
    You could you an Inverter to change from 12v - 230v but it will drain your battery.
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,756
    10,174
    the leisure battery supplies 12volts DC for the lights etc
    the 3 pin sockets are 220volt AC to power anything up to a low wattage kettle
    if you want 220volts from a battery you need an inverter, but they use up the power in a battery very quickly
    normally you will only get mains voltage when plugged into the mains electric hookup :thumb:
  4. paulweller84
    Oct 24, 2013
    19
    Southampton
    Thanks for that, really liking this forum. Seem to get very quick answers! :)
    • Like it Like it x 1
  5. buffallobill
    buffallobill
    Sep 21, 2013
    58
    46
    skipton
    if we dont have mains hook up, sometimes we start the portable generator to charge batteries and watch mains telly at the same time.:thumb:
  6. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,599
    7,882
  7. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Whilst you can use a mains TV with an inverter, it is much preferable to buy a 12V TV as inverters usually waste energy and have noisy fans.
    You don't need to buy an overpriced TV sold specifically for motorhomes. Just buy a normal LED TV. Many standard small TVs will be sold with a 12V adapter which can just be kept in the man drawer and you can buy a replacement 12V lead off eBay. You just need to keep an eye on the individual model to make sure it runs off 12V. Some larger ones will be 19V, and some will be mains, so do check.
    If you do want a large TV and have space for it, you'll struggle to find a 12V model. However, you may find a 19V model, which can run off a laptop power adapter, which is preferable to a mains inverter as you can easily find quiet fan-less models.
  8. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    Check out teh cheap tellies in the supermarkets. Just take a look at the back to see if they use 240v direct or if they use a transformer to feed it 12v. Our 19" inc DVD pl;ayer was £80 - just need a 12v adapter/regulator from Maplins and you can watch on or off EHU. If you want to. As obviouysly real Funsters never watch TV http://www.motorhomefun.co.uk/images/smilies/eek2.gif
  9. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    actualy that polaroid tv will work off 12v . i have one of them and it works off 240mains but that changes the powe to 12 v. i found a lead with the same jack plug in my collection of might come in handy one day items .and now run it straight off 12v .
  10. paulweller84
    Oct 24, 2013
    19
    Southampton
    What sort of lead do you mean? Is it a lead with a cigarette lighter plug that goes straight into the tv without a DC converter?
    You haven't got a photo of it or a link to one somewhere by any chance?
  11. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    Something like this...
    [​IMG]
    http://www.ebay.co.uk/sch/i.html?_trksid=p2047675.m570.l1313.TR1.TRC0.A0.X12v+tv+lead+cigarette+lighter&_nkw=12v+tv+lead+cigarette+lighter&_sacat=0&_from=R40
    Just make sure you get the right size plug to fit into your TV's 12V supply socket.
    If unsure which one size plug you need take the existing power lead from the 240V brick transformer, into somewhere like Maplins and match it up to find the correct size.
  12. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,662
    14,456
    North Lincolnshire
    We have a 240v / 12v tv/dvd combo.
    It will obviously work on hook up, but works just as well on 12v.
    12v satellite tuner also.
    Both remain plugged in to 12v, even on EHU.
    On an extended weekend, 12v runs our tv / sat, lights, water pump, etc.
    To boil a kettle, we use the gas cooker.
    No extra power is needed.
    I cant see the need to run gennies just to watch tv, nor can I see the need for an inverter unless hair dryers and the like are needed.
    They can drain a battery pretty quickly.
    I've seen folk running gennies on the evening of day one of a weekend trip, and in some cases on overnights when they have moved on in the morning.
    Surely, if they need to do this, the batteries are knackered?
    I bought a genny, broke it, fixed it, it now lives unused in the garage at home.
  13. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    thats the kiddy .i had a few old leads of alsorts of past gear . works a treat i use a similer one for the ariel . no sat just one of these.http://www.ebay.co.uk/itm/261043446948?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
    works a treat . use it here and abroad for local channels .
  14. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    If you want a decent TV with even more important, a good sound that isn`t tinny or low, also picture is clear and not distorted when viewed at an angle, go for an Avtex, run on 12 volt or mains,I keep it in the 12volt whether on battery or mains, I have the 16 "with cd/dvd hubby bought the 22"with cd/dvd for the caravan, we also use that one in the kitchen at home.Highly recommended
  15. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,662
    14,456
    North Lincolnshire
    That's the one.
  16. Volusia
    Volusia
    Oct 2, 2013
    206
    174
    Haute Vienne France
    Use of an inverter for tv an computer use is a bit risky unless the inverter is the pure sine wave type. These are much more expensive than the normal or quasi types but are perfectly safe with delicate equipment.
  17. Larby
    Larby Funster
    Jun 17, 2012
    1,779
    4,082
    North Essex
    I use a 350 watt inverter that is connected to a separate 240v 4 socket extension. So I use that to drive a 240v TV (80watts) and a Freesat box (20 watts). This means boss gets her "soaps" and I get fed. Also handy for laptop and mobile charging.
    I spent 4 weeks in France without hook-up. The leisure battery gets charged from the alternator when on the move. I spent 2 weeks in 1 place and then the solar panel charged up the leisure battery. :thumb: (and set up so the vehicle battery gets a trickle of all the lovely free leccy as well)
    Forget 3 pin sockets without hook-up if you are thinking of hairdriers, toasters and kettles etc. Use gas to cook and heat and tell the wife to use a thing called a towel to dry hair, or start up the huge hairdrier under the bonnet and use the heater vents.
  18. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    695
    404
    Rugby UK
    I had a 1500watt invertor fitted, they also fitted a 3 way switch, Mains / Battery / Inverter, so I switch this to the required position and can have all the 240v plugs live either from mains or invertor but I do have to in addition turn the invertor on, I have learnt a lesson and have to ensure the tech tower is turned from auto to gas to ensure the battery does not power the fridge freezer, I use this to power the microwave / laptop charger in small doses. Last year when I left the wife by herself in the van for a couple of days she left everything on and flattened everthing including the starter battery and I had to get the RAC out to start it !!
    It works very well but it is complicated, the 2 x 225amp trashed batteries never really recovered properly and I have just replaced them.
