dawny
Hope someone can help me. I have just bought a motorhome which has a satelite dish, i cannot use a normal free view and need a satelite digital box. Please could someone tell me which one and what the heck it is>
Hi, Dawney, if your interested I have a spare Fortistar Free to air box lying about.
Yours if you just cover the postage
PM me if interested
if you go to Halfroids they will be expencive. However[There are 12v and 240V versions of these boxes, for the 240V type you need either to be on an electric hookup (EHU) on a site or have a small inverter that changes 12V DC into 240V AC 150W is sufficient.
Thank you so much!! I have been looking at these inverters and they are quite expensive, the man at halfords said I needed a 300w??? To run a tv? This is a minefield of confusion!
how do you come to that conclusion Jock......Hi Dawny,
It sounds like you may have a Maxview crank up dish. Roger's advice re alignment is true, ie, no way out of that one, but once well practised, you'll be able to lock into the satellite signal quicker than those with motorised dishes.
12v digital satellite receivers are like gold dust, and hold their price well. A 240v FTA or Freesat receiver used via a small 75 watt inverter, is often the cheapest way to go. 12v LCD/LED TVs are common place now, and can be purchased for around the £100 mark.
If you can join a meet or rally, there will be plenty of "hands on" Funsters to help you.
Good luck with it all, and when you've sorted the satellite receiver and TV out, it'll be something else that will test your knowledge and patience. Just ask away though. :thumb:
Cheers,
Jock.
P.S. Welcome to Fun.
What I meant John, was the likes of the Pace 12v Sky Satellite Receiver, which I should have mentioned earlier. At one time, that was the only 12v receiver money could buy. Obviously things have moved on as your link clearly shows.how do you come to that conclusion Jock......
click the link to eBay...new receivers start at £29...and every one on these two pages is 12volt
http://www.ebay.co.uk/sch/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A6003&rt=nc&_nkw=fta+satellite+receiver&_trksid=p3286.c0.m2000018.l2552&_pgn=1
but which Astra satellite.....you may be tuned to Astra 1 which shows an awful lot of foreign channels and next to no English ones....maybe sky news..CNN etcI have just fitted a free to air tv/dvd.
Also have a portable sat dish, i have the signal ,tuned the tv in to dvb,but all i seem to get is Spanish channels
I have been through most of the menus,found a Muslem channel, but i can`t find BBC ect!
It says Astra sat i am tuned to.
HElp :thumb:
OK, I have done that, now on the set up list ,they ask about transponders/east/west/ ect--i don`t know which numbers to pick--and will i have to store them in the tv?but which Astra satellite.....you may be tuned to Astra 1 which shows an awful lot of foreign channels and next to no English ones....maybe sky news..CNN etc
you need Astra 2 or Astra N1 as it is now
the parameters and transponder setting should already be stored for each satellite and shouldn't need adjusting.OK, I have done that, now on the set up list ,they ask about transponders/east/west/ ect--i don`t know which numbers to pick--and will i have to store them in the tv?
Is there a standard set up for UK ie: astra no 1/ transponder--- ect? ect:
I know nothing about sat dishes only that freesat is routed from my old sky dish in the house .
Not much hair left to pull now!the parameters and transponder setting should already be stored for each satellite and shouldn't need adjusting.
as long as you are on Astra N1 or Astra 2 then simply exit the menu and scan for channels
