please help (1 Viewer)
Kevfromwales
30
Gloucester
Hi Top
Problem with Fiat mh 600se when travelling I lose all power and when I stop and wait a few minutes it will start again and then after a few or more miles it does the same again.:Sad:
IrasciBill
194
37
SW Scotland
Auto-Roller 500
Since 2009 (after many years camping)
Help
Hi Kev, Have you checked that the fuel tank vent is not blocked?
chatter
3,689
937
cheshire
5th wheel
Had similar happen with a renault car, it was found to be a faulty sensor, trouble was because it was intermittant it took ages to find the problem as everytime they hooked up it showed no problems anywhere, and it was like - not that we dont believe you but we cant find anything wrong
sue1959
619
Ireland
non as yet, hired in Canada a couple of times. hope to buy in the next few years.
Had the same problem with my deisel golf, would happen at the most inconvenient times. It needed a new relay switch.
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi same type of problem was caused by air flow meter
terry
Kevfromwales
Kevfromwales
30
Gloucester
Hi Top
I know how you feel nightmare
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Check the hoses that go to and from the turbocharger. These ofetn become loose and if the airflow into the turbo is disrupted the EMS puts the engine into "limp home mode" so you will only get 30mph ou of it to stop you blowing things up. Just a thought
Phill
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
And if this was a bike or a SMALL Fiat such as a Panda and the like I would have said inlet icing
The air being drawn in freezes and reduces the inlet tract ( effectively chocking the poor thing )
Stop, the heat from the engine melts the ice in the tract and all is fine again ( for a while )
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Charge relay on its' way out. They sometimes get sticky, and they stop charging so the engine will cut out to protect itself. You may find the battery light pops on for a second before it stalls. Not too expensive.
You could try popping the relay out and checking the connections, may just be dirty - check your drive belt tension as well in case it is slipping.
lorger
9,661
90,506
Dumfries
Knaus Sun 650MEG
had the same problem with a v/hall frontera diesel it started like your and got worse over a few weeks eventually found a tiny hairline crack in a injector pipe changed that and was fine after that.
Gerry
