plastic crack
Discussion in 'Tech/Mech General' started by webmonkeyuk, Feb 17, 2011.
  1. webmonkeyuk
    webmonkeyuk Read Only Funster
    Feb 10, 2011
    5
    stockton on tees
    Ive had my motorhome stored over winter at a storage site and ive had my full cover over the motorhome to keep the snow/rain off it, anyway i decided now that its getting abit nicer and im planing on using it next month id take the cover off. so ive been down today and removed the cover only to find about a 3 inch crack in the outside plastic bodywork from the drivers side rear window. if anyone is familler with a swift royal 610 you might know what i mean.
    it comes from the window frame down to the gas bottle storage locker. ive only had the motorhome since october and i wasnt planning on this :Sad: ive no idea what could of happened my only guess is it didnt like our -15c temps we had over winter. any way can this be fixed and what sort of price would i be looking at, i was thinking of having ago myself using a resin repair kit and maybe some cataloy filler.
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,349
    77,860
    Sutton on Sea
    Wow:Sad: Could you take a picture and post it so we can take a look?
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,927
    17,587
    YO11 2BD
    does the crack go right through the outer skin to the foam core or is it just the outer gel coat which has cracked ?
    sounds very much like a leak around the window and the harsh weather has frozen the damp core and swollen causing the crack.
    if it goes right through i'd get a proffesional job done as it may have compromised the structural strength.
    gel coat crack should be fixable with resin/filler.
  4. webmonkeyuk
    Feb 10, 2011
    5
    stockton on tees
    both sides around the crack move if you touch them, im not sure if it goes right through as i didnt want to pull at it but id say from looking its just the outer skin that has split. i will try and get a photo when im there next
  5. pappajohn
    Aug 26, 2007
    29,927
    17,587
    YO11 2BD
    if both sides of the crack move independantly of each other i'd say theres a good chance its cracked all the way through the gel coat and outer skin.
    i reckon repairing with filler and resin wont last long as the body will flex enough to crack it again.
  6. hilldweller
    Dec 5, 2008
    27,209
    26,203
    Macclesfield
    I've read that line before. A good while ago. Have a good search on here because I think it was major repair job done FOC because the window was fitted badly. If you can't find it on here use Google.
    I think it was Swift too, but so many complaints are I may be confused.
  7. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    there was a similar post on this sort of crack happening to a Autotrail on the other motorhome site , from what i remember it went back to autotrail for the repair
  8. sedge
    sedge Funster
    Jul 7, 2009
    4,558
    4,053
    Nr Jct 3 M6
    Brian
    Why pick on Swifts!! Have you seriously never met anyone with another make that didn't have a catalogue of disasters?
    Like the couple we met first time out who "always had Hymers" - but the latest had to go back 20+ times to get stuff fixed!
    (And they paid over £20k more than us for their beastie for much the same accommodation but without an oven or microwave and with a smaller bathroom. Did have much nicer curtains though!)
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Hi webmonkeyuk and welcome :thumb: I remember reading similar items on both Autotrail and Swift. :BigGrin::Wink: In both cases (several ) they were returned to the manufactures who ended up replacing the entire sides of the vans.
    How old is your van, you say you only got it in October ?If new you have the answer :thumb: If out of G/Tee - I believe 6 yrs but may be wrong- no doubt they will wriggle out of it :Eeek: then short of replacing the entire side the best way to effect a repair would be to tackle it from inside strengthening about 6 ins( 150mm ) either side of the crack with a fibreglass patch and then doing the same to the inside wall.Once that is done then tackle the out side skin repair:thumb:
    terry
  10. webmonkeyuk
    Feb 10, 2011
    5
    stockton on tees
    the van is a 1997 p reg so i doubt swift would be interested but as far as i can see all the window frames are sealed very good with proper silicon so ive no idea how it managed to crack still, ive had alook today and by the looks of it the problem is limited to the outside skin. ive shopped around for some quotes and there getting back to me but im thinking it might repair with the use of some fibreglass patches and some strong resin. we shall see i guess
  11. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    Make sure you find out what material is first ie grp acrylic abs etc as it effects how to repair it:thumb:
  12. hilldweller
    Dec 5, 2008
    27,209
    26,203
    Macclesfield
    If it is fibreglass do some Googling and include scarf joint in some of the searches.
