Plastic basins (1 Viewer)
janeerica
9
17
Godalmig
RAPIDO
I'm a newbie
My new-to-me motorhome is very tidy except the plastic basin in the bathroom which has yellow staining and so any tips you may have for returning it to a whiter shade of pale would be much appreciated. It really isn't the end of the world, and is just something I'd quite like to do. Internet tips seem to revolve around caustic soda which seems a bit harsh!
Regards Jane
Dec 24, 2009
1,067
15,691
bedworth warks
c class
2009 previously a tugger for thirty years
Personally I would try using Jif. It wont scour the surface of the plastic and hopefully will get what is probably lime scale from the sink.
scotjimland
2,246
9,757
A Woosh bang
Trial and error I think.. if it's limescale
have you tried white vinegar.. or lemon juice.
or bleach..
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hi, be careful what you use as my showeroom sink disintegrated because I used the wrong product to clean it and it was expensive to replace it as it was a rapido model :rolleyes:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Regards Jane
Is it really staining, or has the plastic itself changed colour? You might be rubbing for ever if the composition and age of the plastic has time altered it.
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
Thetford toilet bowl cleaner can be used on washroom sinks. It cleans and also polishes. Not cheap, but worth a go see here for details.
TheBig1
17,591
43,004
the best solution for discoloured plastics is to paint them after thoroughly cleaning them. easiest and cleanest way is remove them from the van first
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
You shouldn't use bleach on any plastic in motorhomes / caravans it can and will discolour plastic and cause it to become brittle, some mouth washes also cause damage to the plastic, when we had a caravan with a normal cassette toilet when the bowl became slightly discoloured I used to fill it with a strong solution of warm water and puriclean leave it for a couple of hours and just drain and rinse worked a treat, then a wipe round with Lidl's W5 lime scale remover
