Pilote charging (1 Viewer)
philk
173
50
Lancs
since 2000
Hi guys, I am looking for some opinions. We have a 2011 pilote which has scault electrics, 2x90 amp batteries and is plugged into the mains at home.
I nipped in earlier to drain the hot water and tanks etc and noticed on the NASA unit that with lights on the batteries were discharging at 5 amps and nominally showed 12.2v or 51% on the nasa unit. Given i am plugged in I expected more like 13.4 v. I ran the engine and the batteries were taking 13 amps.
If the charger has packed in or a fuse blown its not quite as easy to tell because we have 280 watt of solar.
I have seen something similar on a Hymer where it cycles the batteries and you have to flatten them to get t to charge. Any views?
Philk
43,207
48,801
a good chance thats the problem.
could also be your h/u lead is damaged....do the 230v appliances work when plugged in ?
you could check if its charging on h/u at night when the solar is idle :thumb:
philk
philk
173
50
Lancs
since 2000
Battery
Hi john, i have a test plug thats lit up on all three lights so mains lve and cable ok. The manual suggests that 12 v is ok when the the charger detects standby mut i still thought the transfrmer would drive the lights when plugged in.
Philk
43,207
48,801
Philk
yes it should....the charger will act as a power supply as well as a battery charger.
my kontiki had a three way switch....charge leisure battery or charge engine battery or power 12v without charging either batteries
in any option the lights were brighter on H/U than on battery alone showing the charger was running the 12v
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Philk
Would that be Schaudt ?
If so there are plenty of cases of the charger failing. Mine did.
The factory will overhaul these and accept them direct from the owner.
43,207
48,801
just seen the year of the van...2011....warranty job anyway :thumb:
haganap
12,711
25,969
planet earth
Carthago C Tourer
I'm an oldbie MH number 9
Which to me would say Fuse.
But,
I did learn something from my adoptive Electrical father Hilldweller when he tramped over to the posh part of Cheshire to help me out., and that is that fuses blow for a reason,,,
Incidently Brian, looks like it was that dodgy wire on the toad you found that was causing the problem. :thumb:
kickstart
448
114
south yorkshire, Benidorm
low profile
4 years
Mine did, I have gone this year without EHU and this week will send my unit back to the fatherland.....and hope they are merciful with the bill :roflmto:
